wire colors
Results 1 to 5 of 5
wire colors
    Mar 2012
    Default wire colors
    getting ready to wire the boat what are marine color codes? i got a
    fuel gauge -
    tach -
    water temp -
    oil pressure -
    volt meter -
    bilge pump -
    ignition -
    cigarette lighter -
    thanks in advance and if possible maybe a guess at about how much ill need of each its an 18' jet boat with a bow tank
    Marine Mechanic and boat repair. San Diego, California
    _Marinemechanic.com One Word for Information, A Marine Mechanic and Boat Repair
    Here's a couple links I hope they come through. they don't seem to want to load properly.
    Edit; click on the 2nd link,
    then click on "Index of web pages".
    scroll down to page 101. It has the wire colors. Sorry I couldn't make it just load that page.
    Quote Originally Posted by 73konajet View Post
    fuel gauge - COULD BE PINK OR RED
    tach - GREY
    water temp -BROWN
    oil pressure -BLUE
    volt meter - VIOLET or RED
    bilge pump - ?
    ?ignition - VIOLET
    cigarette lighter -?? LIKLEY RED, VIOLET if switched
    Starter sol YELLOW OR YELLOW w WHITE trace
    Volt meter and test lites are your friend here Tom
    tach - GREY
    water temp -BROWN
    oil pressure -BLUE
    bilge pump - ?
    ?ignition - VIOLET
    Senior Member copterzach's Avatar
    Danny Donahoe with DCM. He has rigged, wired and rewired a lot of boats.
    Senior Member 91foxbody's Avatar
    Stanwood, WA
    Bilge pump is also brown. Sometimes brown with a black stripe
