Great stuff
Results 1 to 14 of 29
Great stuff
    Senior Member bc18's Avatar
    Default Great stuff
    Great stuff black rtv is impossible to get off. Wouldn't recommend using it, use normal black rtv
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    What did you use it on?
    Q.C./Big River
    Quote Originally Posted by nick View Post
    His oil pan.
    Chantilly Va.
    Default Yo
    Quote Originally Posted by bc18 View Post
    I have used "The Right Stuff" This is indeed the best stuff going. Permatex product. The directions read, something like...Apply, then assemble parts then use as normal. Sounds the correct chit to me !!!! I use it in a normal use, in my business daily and havent had an issue as of yet.
    Senior Member Mojave85's Avatar
    Boise, Idaho
    I love the stuff and use it all the time. It is the best thing on the market but a bit spendy.
    I'll admit it's good shit but it's nasty don't plan on an easy disassemble.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    must be a chevy thing to glue your motor together so it doesn't fall apart
    Okmulgee Okla.
    Quote Originally Posted by HBInHeat View Post
    Actualy it was pionered by ford to keep the pistons from scaring the head when the rods gave up, a lil dab ( like flubber ) on top of the piston and the rods went right out the oil pan.
    Damn ford peeps, just cant get good help these days.
    well the block is GM any ways
    IS UNDER FIRE
    Senior Member wolfie's Avatar
    Carb or MAF sensor cleaner. That's what I used.
    Love the Permatex "Right Stuff" , best thing I ever found for intake end seals , you are right though , it really sticks and is very hard to get off once cured Tom
    His oil pan.
    The reason I asked was because I am having sealing issues with my fuel plumbing. I know this may be a stupid question but do other guys have similar issues? I'm talking about when I am making up something like my fuel pressure regulator with my a/n fittings for my fuel lines, I can never get a good seal...I know you're "not supposed too over-tighten" that aluminum stuff but I feel like it never seals and they always leak just enough to bother me. What do you guys use for a thread sealer on this kind of stuff? Nothing, Teflon, goop of some kind???
    I'm hoping this may be usefull information for others and that I'm not alone on this one...
    Kingman/Golden Vly, Az
    The reason I asked was because I am having sealing issues with my fuel plumbing. I know this may be a stupid question but do other guys have similar issues? I'm talking about when I am making up something like my fuel pressure regulator with my a/n fittings for my fuel lines, I can never get a good seal...I know you're "not supposed too over-tighten" that aluminum stuff but I feel like it never seals and they always leak just enough to bother me. What do you guys use for a thread sealer on this kind of stuff? Nothing, Teflon, goop of some kind??? I'm hoping this may be usefull information for others and that I'm not alone on this one...
    i personally use Teflon on all my AN fittings, carbs, gages, regs, also, on pipe fittings on manifolds etc...works great and no issues ...i use a wire brush in a drill to get the rtv silicone off of items i used it on, oil pans, manifolds etc...just my .02 cents
    Permatex thread sealant is what I use on plumbing/an fittings.
    Douglas, MA
