whats the low down on this style of Inducer?
Results 1 to 14 of 18
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Default whats the low down on this style of Inducer?
    Dad bought it years ago.if i remember right they were not that good?maybe somebody has done some better testing or Knows more about them.
Name:	boat floor 007.jpg
Name:	boat floor 008.jpg
Name:	boat floor 009.jpg
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    B1 Racing cs19's Avatar
    That is the Precision Jet Drive billet inducer. Made in Ca.
    B1Racing.net
    does it work as is or does it need to be turned down?
    S CP
    S CP
    You still need to turn your shaft and mill the shaft for a keyway like any inducer install, the inducer fits as is, no machining on the part itself.
    We dont run those inducers in any of our stuff.
    B1Racing.net
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    Thats the same one I'm running. It helped alot, but not real sure on how it would perform vs. the DPS or HM
    Until the HM came to be, they all needed work for optimum gains. The HM is almost perfect out of the box.
    lake Ouachita AR
    i was pretty sure that was what it was called.
    my shaft is already set-up for a inducer.
    i guess im wanting to know if they are worth a shit,lol!?
    i need one and if this one will compare to a HTM or a detailed DPS then ill try it.if not ill give it back to Dad and tell him sell it to somebody he doesn't like,lol!
    i think i read some where or heard the pitch on blades was not good?
    hell if i know
    WFLC
    2011 Performer SS
    hell if i know
    I'm pretty sure the blades overlap too much.
    Atlanta TX
    If your not running one now , it should certainly be an improvement. Would be even better if you cut the blades back so they didnt overlap. And lastly if you wanted to go even further you could thin the barrel down a bit. This is all JMO.
    Are DPS inducers any good?
    I have one matched with my SS Aggressor impellor.
    Quote Originally Posted by cpjet View Post
    That's what I was going to do with mine this go around, but I worried about balancing issues. It made such a big improvement over what I had before, which was nothing, I just decided to leave it. Not really looking for tenths at this point.
    DPS was the top of the line till the HM. I thought there would be a flood of DPS inducers on the market with everybody switching over, but there wasnt.
    lake Ouachita AR
    Thanks!
    recon how much i should cut the blades back?
    WFLC
    2011 Performer SS
    San Diego, CA
    hell if i know
    There are others out there that will work better.
    Boat 405.
    Apr 2011
    Its a good inducer. You need to cut /grind the leading edge to be a smooth cut/flow. As it stand now the inducer cut causes the water to jump causing a cavatation and disruption to the water flow. It flows over 5,500 GPM far beyond your pumps output. Just use your hand to get the flow smooth and clean for the Impeller feed you will fill it. Have ran on many Big Dog Boats. Its S/S Billett. Good Luck! If your Dad's Scott tell him Hi Dave Jones!
