i confused myself reading. please help
Results 1 to 14 of 16
    Apr 2012
    Default i confused myself reading. please help
    i have a few pictures off this site that have brought me questions i cant search out. they are of other members boats and not my own. if you know what they are please pick a colored arrow and explain away
    first in red and yellow. these look like some kind of super bearing holder and a clear cup for something jet related
    second in green looks like a transom adapter for a set back and light blue is this welded to the suction housing? i have seen similar set ups in many boats but this is the best picture to draw on
    last pink looks like a double steering system of some sort and teal seems like the support that was mentioned to hold the weight of the jet from taking the transom off, or do i have these mixed up
ID:	157884   Click image for larger version.
ID:	157885   Click image for larger version.
    Norco
    Quote Originally Posted by $uperJoe View Post
    First pic. Its a "jet away" Its like a free wheel rachet on a bike. If the motor blows, the rachet will free wheel so the back of the boat dose not rise causing the nose to stuff on shutdown. Also a cool neutral to have so the impeller does not spin on dry starts.
    The cup is for oil for the bearing.
    Second, yes, transom adaptor. Not welded but silicone for a water seal
    Third. It is a cable steering system lots of racers use. Forgot the name. Some one will chime it. And yes, its a pump support. Keeps things from wanting to move.
    Calgo steering
    Apr 2012
    thank you very much. i was more correct than i thought i would be. back to reading about boats
    Apr 2012
    Default more questions
    i found this picture on CL and was wondering if this is an appropriate plumbing set up.
    to me it looks like the water comes from the large hose under the oil filter, tees off to the engine intake and then a bypass to the exhaust.
    goes through the engine and then to a thermostat that also feeds exhaust. it all seems pretty straight forward as long as the thermostat is functioning correctly. it also seems that an engine at temp would burn more efficiently opposed to a cold engine. i am curious about this set up because i dont know how to get my engine any warmer than a hundred degrees and with the hull swap i feel a few other things need change as well
    question. i do not see a bassett valve for low idle water to exhaust, and if there was one would you put it where the exhaust water supply comes out and just have a separate dump out the boat
    Belive what your seeing is a water jacketeted header setup which is plumbed differently the water injected , not likley there is actually a T stat in the housing Tom
    Apr 2012
    could you please explain the difference tom
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Looks like a sterndrive water system.
    It makes sure the jacketed headers are fed water before the thermostat opens up. Bypass hose going to the top of the tstat housing.
    QE 439 Twin Turbo
    Senior Member bp298's Avatar
    LHC
    when a jetaway is installed, the thrust bearing is lubricated by the jetaway fluid instead of grease. when the fluid gets hot enough, it can pressurize the cavity, resulting in the fluid exiting somewhere. the cup is a bearing oiler, used on some industrial motors. by removing the zirk, the bearing oiler gives the pressurized cavity a place to vent, collecting any jetaway fluid that might have otherwise spilled into the bilge.
    explain what you mean by "an engine at temp" vs a "cold engine"? if you're referring to the WATER temperature gauge, in a jet boat, that is not an accurate measurement of engine temp. it is water exit temp. most all jets have a once through cooling system, meaning lake/river water is pumped through the engine and back into the lake/river. the objective of the system is to remove heat from the engine. not necessarily to obtain a specific temp reading on a gauge. simply put, the heat removed is the product of Tout - Tin x flow rate (lbm/hr). in a given day on a given lake, Tin never changes. if flow rate is increased, Tout decreases. if flow rate is decreased, Tout increases. considering that most lake/river water this time of year is around 50-60 degrees, decreasing flow to the point the Tout gauge reads 180 isn't necessarily a good idea. with this kind of cooling system, oil temp is going to run 70-100 degrees higher than Tout.
    a warm engine is an engine that's nice and warm to the touch, with the oil temp up to normal operating temp.
    you only need a basset valve to feed water injected headers. you don't want water running into the header loops below 1500-2000rpm as you can get into reversion. the spring in the T valve is supposed to close off water flow at 1500 rpm...
    Apr 2012
    this is good to know. i am only familiar with auto systems that recycle the coolant. being that i only get one shot with lake water would it be better practice to put my temp gauge in the oil to measure aprox engine temp, or would a random port in the block be better? also what would a good temp for an engine be based on your location provided?
    Apr 2012
    is this bracket a correct way to extend stringers in the boat? or do you need to replace the whole piece of wood?
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    WTF?
    Who hacked that chunk out of the stringer?
    The best I can tell of what you are asking is the aluminum plates on the stringer look like they are giving support to the 3 point engine mounts.
    If you want a full length stringer boat then "right" way is to install new stringers front to back or in this economy it might be cheaper just finding a boat hull with them allready in it and sell your hull.
    Apr 2012
    Quote Originally Posted by Fonz69 View Post
    WTF?
    i didnt see the motor mount until you pointed it out. i dont know if i want a full stringer boat. i dont understand exactly what the value is compared to the cost to install them, as i havent read on that subject yet
    well stated BP.
    Figured out years ago if we ran the oil temp at 190-200* under cruise conditions and the water temp just ends up being what it is to control the oil temp.
    S CP
