drive shaft ??
Results 1 to 6 of 6
drive shaft ??
    Senior Member flattie's Avatar
    Menominee mi
    Default drive shaft ??
    I set the pump back in my jet and should I have a drive shaft made or should I do a splined shaft with a slide coupler? Whats better? What is cheaper? your thoughts??
    Quote Originally Posted by flattie View Post
    How much set back What hull ?
    Menominee mi
    Sanger super jet... Just enough to get the clean out cover outside the boat. 1978 newer bottom.. Took the hook out of the bottom and cleaned it up... Also made the transom flat. Cut the sanger bubble out of the transom.. I think I moved the pump 4 1/2 inches back
    Menominee mi
    Also put full length stringers in it.
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    PM sent
    One less DEALER means more DISCOUNT for you
    Personally you have to start someplace and since you in somewhat new territory , depending on your engine mount system Id likley move the motor back accordingly and reuse the original drive line to start Tom
