do they sell flappers for angle cut exhaust tips???
Results 1 to 14 of 16
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Default do they sell flappers for angle cut exhaust tips???
    I have some angled cut 3 inch exhaust tips that don't have any flappers do they sell them to install internally.
    3" Internal Butterfly Style Rubber Replacement Exhaust Flapper - Hardin Marine
    3" Internal Butterfly Style Rubber Replacement Exhaust Flapper - CP Performance
    3" Internal Butterfly Style Rubber Replacement Exhaust Flapper - KE Performance
    I have 3 1/2 angle cut... just make sure you always run water through them. They burn out quick. I made it a habit to spray some water based dressing in on them when on trailer. Seems to make them last a bit longer.
    Made In The Shade
    Custom Window Tinting
    Aug 2011
    indy.
    Where and how do they go in I don't even see one in mine. So Idk if its had one in there b4 or not did tgey make any without.
    Feb 2012
    OC, CA
    Best to show a close-up pic of what you have.
    Aug 2011
    indy.
    This is all I got right now ill post more when I get off work thanks.
    The outside looks bigger than 3... does it reduce in size on the inside? If it was to except flappers, there will be two small holes(top and bottom of each other). I have seen them on both ends of exhaust. Mine are on the inside end. If you dont have the holes for them, you need to drill them. The flapper comes with two small press fit bushings and you need to have a vise(if doing out of the boat) or a big C clamp to do inside the boat. I drilled out the bushing a tad to make em slide on easier.
    Made In The Shade
    Aug 2011
    indy.
    Ok I don't think mine is set up for them I don't see any holes. Ill order a pair, and drill in some holes I'm pretty sure there 3 inch ill double check. And yes they are same size all the way back even hose is same all theway to the riser and it fits snug over my riser.
ID:	158821   Click image for larger version.
ID:	158822   Click image for larger version.
    With your type of exhaust, you might not need them. Water has to travel a bit high to get over your riser. I have regular snails and both my flappers only have one side left and ran it that way all last season without water issue. I park my boat with current or nose out when I can.
    Made In The Shade
    Aug 2011
    indy.
    Ya I didn't think I needed them I thought mine was pretty high, I was gonna get some cause some people suggested it.
    Anaheim Hills
    Might as well buy an extra one know as they blow out after time.
    Dallas, TX
    He hydro locked his motor. Couple of members suggested he might need flappers. Either that or he over pressured the block and pushed out a gasket.
    Placentia, CA
    You could cut the angle off and put the clampon external Salisbury rubber flaps on that will last for years. Rex carries them.
    steveo143 AKA DiMarco 21 II
    I doubt water traveled up and over his risers. I have snails and they are much lower to water level with only half my butterfly left. No water issues yet...I think his issue was poor gasket coverage at the riser or manifold intake gasket.
    Made In The Shade
    Dallas, TX
    I bet you are right. Either that or he pushed a gasket out by over pressuring the block.
