Motor tries to die after a WOT pass.
Results 1 to 14 of 17
    Nov 2011
    Default Motor tries to die after a WOT pass.
    Every now and then after making a hard pass the motor tries to die. I have to pump the pedal a little to keep it running. It's a 1050 on a bbc. Would this be a float adjustment?
    Member phil369's Avatar
    N W Ga.
    Read your plugs, sounds lean, also not very safe in a jet, depenging on hull you could get pitched out if it does die. Do you have any other probs anywhere else in carb at other times, hesitation or surge ?
    Bullhead City, AZ
    Raise the floats and or go to bigger needles also check fuel presure !
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Douglas, MA
    as was already said...check the fuel pressure and float levels...it sounds like you are draining the bowls.
    Nov 2011
    Everything else is fine, no hesitation. Fuel pressure is @ 8 pounds. I'll try raising the floats a little and see how it likes that. Thanks, Dan
    Quote Originally Posted by Big_Dan View Post
    when you let of,f the fuel maybe sloshing to the front of the tank, causing it to suck a little air
    #55
    Is this at the top of the pass while still on the throttle ? or on decel? and 8 psi ?
    Bullhead City, AZ
    As I said before needle size is important. I run 130s in my 4150 and 150s in my 4500 and they are stainless. The standard Viaton ones are wselling in todays pump gas, this causes them to let less fuel into the bowls. BTW - we have E-15 at the pump some stations have E-10 in all three grades 85,87,91.
    Jim & Amanda Rich
    CJ 72 & 53c
    CP-Carrillo Piston Maker's Avatar
    Apr 2009
    In the Dungeon
    Bullhead City, AZ
    Quote Originally Posted by Piston Maker View Post
    BTW - That is where my 4500 is headed !
    Jim & Amanda Rich
    CJ 72 & 53c
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Try adding jet extensions in the rear bowl.
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    Very doubtful it would be the same problem but mine would die completely after a WOT pass then fire right back up.
    Turned out the BG electric pump by pass return was plumbed above the port side pickup. The by pass was cavitating at the pickup and the electric pump was losing it's prime. It took me awhile to figure that one out.
    "Pot had helped, and booze; maybe a little blow when you could afford it. Not smack, though" President Barack Obama.
    Liberals just chose to ignore relevant information about the world they live in, and then call themselves sophisticated for having chosen to be more stupid than God made them.
    Sorry to thread jack, but C&J has my carbs right now setting them up for my blower motor. After reading the thread started by Piston Maker and seeing who responded positively, it made the choice easy as to who I was going to use. Talked to John a couple times yesterday, the guy's a pleasure to work with. He makes me feel really at ease. He not only listens well, but takes the time to explain what he's doing and why. I'm sure my carbs will be bolt on ready when I get them back. Thanks Piston Maker, your dad rock's.
    Raise the idle 100 rpm
