Ford Mecanical Fuel Pump
Results 1 to 3 of 3
    Senior Member Quit Yer Bitchin's Avatar
    Jul 2010
    Default Ford Mecanical Fuel Pump
    Does a BBF mechanical fuel pump use an actuator rod like a GM fuel pump? My engine currently has a block off plate and I don't know if I need to buy a rod and a fuel pump or if ford fuel pumps opperate differently and don't use a rod.
    Anaheim/BHC- the Shack
    No. The arm is part of the pump itself, though you will need to make sure the eccentric is on the cam before mounting a mech pump.
    Jul 2010
    Right, got it.
