Advantage jet boat
Results 1 to 8 of 8
Advantage jet boat
    Junior Member azjetfan's Avatar
    May 2012
    Default Advantage jet boat
    Hello,
    Im looking at buying a jet boat. Anyone know what the fuels tank capacity is on an 89 advantage open bow jet boat and how far /how long does that last.
    Thanks.
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Which model?
    18' Ski Sport (Rogers) 28 gal
    18' Tunnel Runner 28 gal
    19' Warrior 38 gal
    20.5 Classic 44 gal
    May 2012
    It's listed as19' open bow, no model given ? Sorry for the noob questions, what's mpg or avg time/ distance a tank wil last? Thanks
    Long Beach
    Quote Originally Posted by 76 Bonneville View Post
    Which model?
    19' Warrior 38 gal
    20.5 Classic 44 gal
    I worked there then, what in the hell is a 18 tunnel runner open bow?
    There should be manufacture tags on the tops of the fuel tank that will give you the capacity. My guess would be about 12-15 per side on the 19.
    Mpg or avg time/ distance will depend on your right foot.
    May 2012
    Long Beach
    Is this the hull you're looking at? I know this one is an outboard but and a hard deck but it should be the one if it's a 19 that's being sold. It was the only 19 in the line up back then. The owner of the shop got these molds and 2 others from a land fill. Don't know who originally tooled them up and and threw them away and we never used the other 2 sets but this one sold now and then. It's got a delta pad bottom on it.
    Valley Center Ca
    Quote Originally Posted by old rigger View Post
    Mpg or avg time/ distance will depend galon your right foot.
    All the specs that I listed, came from the brochure. I've never been able to put more than 36 gals in my 20' Classic.
    I believe the 18' Tunnel Runner was Rogers semi flat bottom and the mold went to ARE Marine in Il
    Long Beach
    I know what the 18 Tunnel Runner is (Dragstar) I was just giving you a hard time thinking someone would make it an open bow out of one.
