Wedge
Results 1 to 11 of 11
Wedge
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Wedge
    For max speed I have to have the place diverter at near its max angle upward causing the water to redirect (loss of efficency). Would putting in a bowl wedge make any difference in top speed by allowing the diverter to be straighter?
    Member BIG JOHNSON's Avatar
    Sep 2011
    I don't think throwing a rooster tail will create maximum speed.
    Maybe you could benefit from a wedge or a droop to lower thrust.
    Sent from my ADR6400L using Tapatalk 2
    Lake Havasu
    My boat makes max speed with the bow trimmed up. The small rooster is a secondary effect
    Senior Member Lildave's Avatar
    Aug 2010
    Bauxite, AR
    Small rooster?
    More details on the setup please...... Shoe? Loader? Droop (none, full, half)?
    If my boat is trimmed all the way up, it makes a lot more than a small rooster!
    Lake Havasu
    1 degree backcut w/ MPD loader and droop. I would think the same rule would apply regardless of setup though. Will water bending through a maxed out (angle) place diverter perform worse than one that is closer to being straight?
    Senior Member yardsale_03's Avatar
    Jul 2009
    I have a 2*wedge in my boat
    I'll see if I have a better side pic if this helps
    Jul 2009
    Pic
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    We have a local guy here with a 19' daytona. He is running like 106 with a pump gas scott schaffrof 565 and a 175 shot. he has to trim his daytona all the way up to get the most mph and ET. kinda weird especially at the track seein him shoot a full roost, but thats where it likes it. i am sure he could benefit from hardware changes, but who would want to with a weekend warrior, pump gas motor.
    2011 Rouse Performance 19'
    WFL Crew
    Dec 2009
    Northern Indiana
    Theoretically you are better off using the wedge to determine exit angle and run with the divertor in a neutral position. You know, lower velocity there than at the nozzel so less fluid loss. Like I said, "thoretically". Wedges are pretty cheap and easy to change. Every boat reacts different. Buy a couple and experiment.
    Southwest corner AR
    Looking at Yardsale's picture that is 2* down wedge! JMO! I have looked at a few setups on tunnel boats and it seem that alot of them work well with a stright exit! Maybe a Place Diverter short droop with the 3.5-4.0* pin would work best! Because a full droop has a 7* pin and with a 2* down wedge would end up at 5* total before the Place Diverter! I have also seen a HTP Snoot work well on tunnels too! But as I said was just my opinion! Good luck!
    WT
    WFL Crew!!!
    Jul 2009
    Quote Originally Posted by Master Sergeant View Post
    with my daytona if it is all the way trimed up an throwing a nar rooster tail the boat slows down alot
    so i have a diverter stop were the boat gets the most speed out of it . just sharing what i have learned so far with my boat
