capped it, the finished product.
Results 1 to 12 of 12
    old HB member. 4604me's Avatar
    oxnard ca.
    Default capped it, the finished product.
    last month or so, i posted a thread called "capped it now what" i didn't know where to go with my paint scheme. so here is what i sarted with. and here's what i ended up with. what do you think thank's Steve.
Name:	restoring boat 014.jpg
ID:	9266   Click image for larger version.
Name:	restoring boat 013.jpg
ID:	9267   Click image for larger version.
Name:	restoring boat 012.jpg
ID:	9268   Click image for larger version.
ID:	9269   Click image for larger version.
    just a half turn before it breaks.
    oxnard ca.
    more pic's, sorry i don't know how to make them big. steve
ID:	9271   Click image for larger version.
ID:	9272   Click image for larger version.
ID:	9273   Click image for larger version.
ID:	9275   Click image for larger version.
    Silverdale, Washington
    Holy Cow! That looks fantastic. Congratulations for a job very well done. Something about a capped boat that just looks sick (IMO). I love the brushwork on the deck too.
    Great job.......john
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    Thumbs up
    Nice,well worth the effort
    oxnard ca.
    even more pics
Name:	boat pics-2 069.jpg
ID:	9339   Click image for larger version.
Name:	boat pics-2 078.jpg
ID:	9340   Click image for larger version.
ID:	9341   Click image for larger version.
ID:	9342   Click image for larger version.
    Member TrynPas's Avatar
    Litchfield Park, AZ
    Looks great!! I really like the way the paint follows the lines of the hull. Awesome!!!!
    Big River Boy Pebo's Avatar
    Apple Valley/BigRiver/BigBear
    Nice job !!
    oxnard ca.
    thanks i knew i had to do somthing with that line on the side of the boat. the pics don't do it justice. the light blue just pops against that ford white. thanks for the comps.steve
    gilbert,arizona
    Nice looking boat,nice job!!! How did you get that seam as nice as you did,I tryed on my hallett jet and looked good ,but always seem like the seam kept coming back.. what material did you use to get this that nice, i want to attempt it again,i like the look.I need to use the right material,not bondo etc.thanks for any help..
    oxnard ca.
    blownmantra, on the seam you have to groove it to a V shape, it dosn,t have to be that wide mabe 1/2" to 3/4" . i used "kitty hair" or you could use marglass to fill the groove,block it out, then ran two strips of glass cloth over that.block it out,then i used evercoat and sanded to finish. primed it with some heavy ass industrial primer (forgot the name), used ppg paint, dupont clear. alot of wet sanding and buffing to make it look sweeeet. hope that helps, and thanks for the comp. steve
    Senior Member 69sleekcraft's Avatar
    VA.
    Quote Originally Posted by 4604me View Post
    Did you lay glass on the inside? I did not when my sleekcraft was done the same way and it cracked in the seam. Hope you do'nt have that problem.
    Senior Member advantage21's Avatar
    Moreno Valley
    Thumbs up
    Very nice a job well done
    Boatless
