Had a bbc build for paint trade
Results 1 to 14 of 22
    DEG
    DEG is offline
    Senior Member DEG's Avatar
    Mar 2012
    Default Had a bbc build for paint trade
    Fuckit!
    Aug 2010
    Senior Member lbhsbz's Avatar
    Long Beach
    Slow down, take a deep breath, gather your thought, then post your question.
    Chico, Ca
    It made 1 thump, so you are going to tear it down? If you are going to try to blow up an engine you think is old and abused....at least follow through and blow that crap up! 1 thump doesn't mean jack! I wanna see windows in the side of that thing! Take pictures.....
    Oh, btw, sounds like maybe you got shafted, however it also sounds like engines aren't exactly your thing.....so....
    I try to stay away from work trades that both need to be finished. I want to see complete parts or engines that I'm trading the work for. Only one side should be "to be done" work. At least that's just me.
    DEG
    DEG is offline
    Mar 2012
    It is blown..
    DEG
    DEG is offline
    Mar 2012
    And I do know motors.. Just trusted a fellow boater and friend and got hosed!!
    It has a blower? Or it's trashed?
    Did you specify what you wanted in the engine? During the trade conversation ?
    #55
    Redding, CA
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    DEG
    DEG is offline
    Mar 2012
    I don't expect you can.. But the fucking pos! That screwed me out of $8,500 that is on this forum sure does..
    San Clemente
    this should be a show tonight... its like being on racedezert for the water...
    DEG
    DEG is offline
    Mar 2012
    DEG
    DEG is offline
    Mar 2012
    Senior Member River Dad's Avatar
    Riverside, CA
    Any idea what caused the failure? Did you pull it apart yet? Had one torn down from a "reputable" shop that had two rods in backwards once
    DEG
    DEG is offline
    Mar 2012
    So far.. Push rods are different as in a few from another motor. Two rods are too... I found where the motor came from too.. Out of a 72 impala. Totally stock and with a ton of miles all that was done was he Put new bearings and some pretty crap on the outside.. So I'm going to start from scratch! Im thinking use the 402 block still flat top pistons and L29 heads. What do you think? And sorry.. Just really not a happy guy.. That was a lot of work painting that boat for nothing at all!!
