Got motor ready to drop in need need plumbing diagram for cooling lines.
Results 1 to 9 of 9
    Mike
    Mar 2012
    Southgate, Mi
    Default Got motor ready to drop in need need plumbing diagram for cooling lines.
    I have been working extra hard to get the motor done and now I have it ready to install. I am looking for a correct diagram for routing the cooling lines from the water outlet on the pump to the engine and exhaust. I have a berk JE with a BBC and water logs. woould like to plumb for land running of the engine also. Any and all help would be great !! It's been 23yrs since I had my last jet boat and I can't wait to get this one in the water !! The bow rider with the 4 banger just didn't cut it any more !! I NEED SPEED AND NOISE !!! Woo Hoo !!
    Mike
    jetH20
    Kingman/Golden Vly, Az
    do a search...there are schmatic's on here on how to properly plumb your water lines ...easy peezy!!! ...also...info on how to "correctly" run your motor on the trailer
    Made In The Shade
    Custom Window Tinting
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    thats the one!
    Surprise, AZ
    I thought jet boats were air cooled? And you just held the loud pedal to the floor while running on land! Shouldn't the prop move enough dirt at wfo to get you where you're going?
    Mike
    Mar 2012
    Southgate, Mi
    Cool Would it be overkill ??
    Would it be over kill if I have the sorce to plumb all the water lines in stainless steel line ? Or what type of hose should I use to withstand the pressure and temp ? Thanks !
    JetH20
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    Quote Originally Posted by jetH20 View Post
    JetH20
    Many use the #10 braided stainless. See a little in pic below.
    Contact Jim over at performance jet or Tom at jet boat performance, they can advise and hook you up.
    I used push lock -10 and covered the red part with black heat shrink.
    Made In The Shade
    Douglas, MA
    JetH20
    Overkill? ABSOLUTELY....but isn't that what jet boats are all about?
