place diverter bleeding
Results 1 to 10 of 10
    Sep 2009
    Chicago, IL
    Default place diverter bleeding
    Okay, I'm about ready to start punching random people in the face because of this place diverter. All the electric is fine. It'll work for maybe 2. Up/down. Cycles, then. Stop. What is the deal with this thing?! What is the proper procedure for bleeding the lines? Ive already spent way too long fighting this!
    I really dig my manual PD...
    Made In The Shade
    Custom Window Tinting
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    First one getting punched in the face lol.
    Dallas, TX
    They are pretty simple devices. Those Bennett pumps are self bleeding. Typically issue occur when there is not a good solid connection straight to the battery for both power and ground or when a solenoid does not have a good ground to the pump body. The solenoids should only be lightly tightened with your fingers. I had an issue with mine last season with it not wanting to move up more than once or twice. I screwed the solenoids in and out about a 1/4 turn several times and the issue went away for the rest of the season. Is this a new unit or a used one? Are you using diodes or just switches?
    Sep 2009
    Chicago, IL
    Quote Originally Posted by Elkidminoltu View Post
    Haha, yeah, you'd better watch it!
    Well, I searched around before I posted, I disconnected the solenoids from the wiring harness, and went straight to battery with them to bypass any power/ground problems. No diodes, just switch. (i didn't wire it, guy before me did. Worked last year beforr the motor went out.)
    Dallas, TX
    Read your other thread. I have no idea. Maybe buy a new pump and move on.
    Sep 2009
    Chicago, IL
    Lol, I know right?! I think we came to the conclusion that it has to be the pump. I'm taking it buy the place that replaced the motor for me and see if he has any ideas.
    Quote Originally Posted by PowerAddict View Post
    Sounds like a pump but... call Tim at Place Diverter, has some tips and trick always helpfull 714 870 7140
    Senior Member cave's Avatar
    Mesa, AZ
    When I had issues like this the problem was always the wiring. My ground wasnt solid. Also note the the Bennett pump requires a full 12 volts. to function. Try placing a battery charger on the battery if all your wiring is solid. i recently left my bilge pump and lights on all night along with some other electrical items that killed my battery enough to keep the pump from functioning.
    Takin it home
    031 RIVER4FUN's Avatar
    This happened to me twice. The last time was just before the Elsinore race. It would go up but only go down when I would play with the up - down buttons. Replaced the Hydraulic cylinder, problem solved. Turned out to be a bad O-ring in the cylinder both times.
