advancing stock cam?
Results 1 to 5 of 5
    Apr 2010
    Default advancing stock cam?
    good idea?
    benefits, downsides indifference?
    what does advancing the cam a few deg do?
    Oct 2010
    LAS VEGAS,NV/Ft Wayne-in
    Quote Originally Posted by southwind74 View Post
    good idea?
    Leave it straight up !!!
    You gain nothing if ya do any adj.
    Just saying
    Apr 2010
    its already advanced some don't know how much, i didn't do it the last mechanic did.
    runs good. just poor idle...
    i know some aftermarket cams want you to install them with some adv. why?
    Depends on what you are wanting to do. By advancing or retarding you can change where you max power and torque are at. If you advance the cam say 4* you will develop more power at a lower rpm. Retard it and normally you will see a high rpm increase. You must be sure to check valve to piston clearance as well. That is the short of it.
    Apr 2010
    ok.
    poor idle (lopes from 500-100) shouldn't be caused by an advanced cam.
    everything else is stock.
    runs good does about 60 in an 18 ft.
