Holley Carb issues
Results 1 to 8 of 8
Holley Carb issues
    Idaho Jet Craig4937's Avatar
    Aug 2009
    Default Holley Carb issues
    I have a Holley 4150 Double Pumper with Mech. Sec. and i am rebuilding it but I am having a hell of a time getting the metering blocks off the body. Any Idea's? I have heard use a putty knife and be careful. i don't want to break off the plastic vents.
    Craig
    Sep 2011
    Wrap a shop rag around the metering block and put it in the vise and tap the body with a rubber mallet while holding it so it doesn't fall once it breaks lose.
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    I've always had good luck hitting corner of metering block with plastic/rubber dead blow hammer to get them off. I would suggest against using any putty knife/screwdriver to pry between body and metering block.
    Aug 2009
    Quote Originally Posted by S&S View Post
    I did hit it with a dead blow hammer HARD! but no luck! I did take a putty knife with some PB Blaster and worked them free. It was tough though...NOW how do you get the gaskets off!?! Will some spray gasket remover work? or whats the best thing...
    Craig
    Feb 2012
    OC, CA
    Quote Originally Posted by Craig4937 View Post
    Craig
    Carb cleaner and a plastic putty knife.
    Senior Member GRoper's Avatar
    One gallon can of carb/parts cleaner and soak it.
    Sep 2009
    Chicago, IL
    Quote Originally Posted by GRoper View Post
    What he said. Just did mine. Soak about 30-45 minutes
    Senior Member BAHNER79AUSTRALIA's Avatar
    Jan 2010
    Australia, N.S.W.
    I soaked my metering plates and main body in boiling water for 10 mins. It weakened up the existing paper gaskets enough to razor them off.
    If its too loud.... Your too old....
