place rudder??
Results 1 to 14 of 17
place rudder??
    Apr 2012
    Default place rudder??
    so looking at the place site they offer a small and large rudder for their product. is there any reason to not want a large one, aside from it costs slightly more. would some boats benefit from some increased steering but not a lot?
    reason i ask is because my pile is a bitc# to keep going in some manner aside from crazy in the no wake zone. i feel that before i installed it the standard rudder that was on my setup would carve the slow water in a very predictable manner and would like that back.
    does anyone have a large or even a small used one that will fit the place i could buy or borrow? i have two factory aluminum and one plastic rudders i cant seem to come up with a way to mod to fit my application
    thanks
    Joe
    Sep 2011
    I have the large white rudder that I'll sell for $65, shipping included. This has the 4 hole flat pad mounting.
    Member chevellesb406's Avatar
    Nov 2011
    Yorba Linda, CA
    I recently upgraded from a small rudder to the large Place brand one, it really did help especially in the no wake zones, not chasing the tail anymore, it gets my .
    Douglas, MA
    no droops? huh.
    The large rudder is designed to improve low speed manuverability and control. This should not be used with droop snoots.This size works great on 19' boats and greater. Available in white, black or polished.
    Add this on to any Place Diverter just by drilling 2 1/4" holes on the bottom of your Place Diverter..Newer Diverters are pre-drilled for rudders,so just romove the pin and bolt up.Its that easy..
    Nov 2011
    Yorba Linda, CA
    mines on there with a Place Diverter droop, I don't see any negatives, what's the theory on not using with a droop? My application is a 22' daycruiser.
    Apr 2012
    Quote Originally Posted by chevellesb406 View Post
    thats exactly what im looking for. i didnt know how to describe it as well. "chasing the tail" is perfect. i had a trip planned out to take mom out for mothers day but engine failure pushed it back until yesterday. i dont really have an issue with it buy my mom took the wheel a bit yesterday and she couldnt for the life of her keep the boat even remotely in one direction. at some points we were actually turned around the wrong way. it was all fun and games until the only time she found straight was aimed at the rocks.
    if (when) i upgrade to a droop could i just cut some off the large rudder if it cuts too hard?
    Apr 2012
    Quote Originally Posted by CarbonMonoxide View Post
    is this different than the standard mount style like this?
    Sep 2011
    Here
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Quote Originally Posted by $uperJoe View Post
    You probably need to put a locator dot on the steering wheel to help show the driver were straight is. She was probably over correcting a bunch, happens when I let the little ones sit on my lap and drive. They expect the boat to react instantly like a car. I took nail polish and put a small white dot on my steering wheel.
    Shell Knob, MO
    Here
    That is a Dominator Rudder, not Place.
    Duane HTP
    May 2012
    My boat also was all over the place under say 5mph. put the small rudder on(have droop) and handling improved greatly. glad I did it. the slide in turns is changed thou
    1990 ultra 21' open bow. 509, American turbine Jet
    Apr 2012
    Quote Originally Posted by limited View Post
    hhhmmmmm. i must be not boating hard enough as ive never slid through the turns
    Senior Member 454 blue boat's Avatar
    I have this same one polished I would sell it to you for 50.00 plus the shipping or if you are close enough we can figure it out some way. Let me know its just like new
    I have the large one just like the large polished one in the above pic
    done deal
