best bowl
Results 1 to 3 of 3
best bowl
    Santee, CA
    Default best bowl
    I have a berkeley 12je and it has to be completely rebuilt. The shaft, impeller and bowl are toast. If i get a used bowl, what one should i go after. Btw JP marine in lakeside has it right now. $2500 total to pull the motor, rebuild the jet, replace some hoses and spark plug wires and install a couple control cables. I am going to scrape and clean the manifold for new gaskets cauase its leaking water.
    Member Bam Bam's Avatar
    Sep 2011
    LA (Lower Arkansas)
    Default Wow!!!
    Wish I could land a few jobs here in southwest Arkansas that paid that well! If you don't mind me asking how much of that is labor???
    If I can't fix it you got a REAL problem!!
    Santee, CA
    Not sure, he just called me with that news 10min. Ago, was too busy crying to ask. The shaft, impeller and bowl are being replaced, along with all the other small parts of the jet drive. At least $1000 of it is labor.
