Water Pressure Questions
Results 1 to 7 of 7
    Anaheim Hills
    Default Water Pressure Questions
    So I have a water pressure regulator that was in my boat and before I put it back in, I want to make sure it's right for my application. 1st Question would be: What water pressure should be aiming for? How much is too much? The regulator I have is adjustable from 25-75psi, but I have heard that 15-20psi is the max I should have. i had it set to 25 psi. Where should install gauge to read it? Just after the regulator or from the block?
    Quote Originally Posted by NiceGuyEddie View Post
    from the block, I personally like to bypass water at the thermostat area, that way if your reg fails the blo0ck still has water.
    BTW need an oil cooler
    #55
    MAMA TRIED BENSE's Avatar
    SOMEWHERE BETWEEN HEAVEN & HELL
    I would run guage a temporary guage (unless u want to leave it) after reg or in manifold to check pressure. 15-20. Anything over 25 i'd start worrying about pushing gasket.
    FILTHY FEW
    Anaheim Hills
    Thanks guys.
    Outlaw I have a Rex 2". You have a 3" or?
    What ever you sold me. 2 I think
    I purchased one with the built in thermostat from CP
    #55
    I like to see 25-30#. That's usually not a problem for gaskets and helps prevent steam pocketing and air bubbles in the system. It's an open system, not like a car.
    Anaheim Hills
