iceing up the manifold.
Results 1 to 8 of 8
    sacramento
    Default iceing up the manifold.
    i first ran the new turbos with massive richness, 110 secondary jets drilled out & power valves (2) drilled to .120 . ..well it was real fat but if i remember right it cleared up & ate it all. in the prosses of that i seen the manifold under the carb was iced!. ..anyway i forgot to turn on the water cooling to the turbos, carb housing & oil cooler. i also dont remember seeing the maniford iced up ever again.....my thoughts were that now the turbos are bigger the motor is pulling enough air to ice the manifold up & water cooling now is actually heating the manifold even if it is 60* water. ( higher temp than 32*) ......so iced up manifold flowing fuel ,entering into the turbo, exta cold,less heat upon compression of the boost prosses, more power! i think i will need to replumb . any thoughts to this guys?
    Default Frosty...
    Not sure if it's related, but it is quite common to "frost" up a NA tunnel ram....
    Ray
    LOUD BOATS SAVE LIVES
    okie, lake Texoma
    The ports through the bottom of that Carb box are actually designed to put a little heat into the carb to help the engine "warm up" and idle better. Many schematics actually showed oil going through there instead of water. I always just had mine plugged and never had any ill effects from it. JMO
    H8-2-W8
    [email protected] first pass
    Ada, Michigan
    Why did you drill out the jets ?
    Go back to the stock size jets and power valves and try it that way first.
    With the A/F ratio, rather than thinking, "make it fat" think about, "make it right"
    Use an O2 sensor. Shoot for 11.7:1 with a turbo engine running high boost. 12:1 with low boost.
    sacramento
    it always ran to lean. i had to do the work on the carb to get it not to melt pistons. with that in mind i know i was going more hp with bigger turbos so i did everything that i could to get fuel to flow for the higher boost. well it worked real good so now i am pulling fuel out. it ran lean . i got oil coming out of the right turbo! i think i still am getting water in the oil with no pressure at all! hooked it to the hose & ran it with it exiting out the pipes & pump . looked like it might have risen the oil level. not sure. hard to read the dipstick. i am going to the lake to wrench & figure this out it might be reversion if one of the logs is cracked? or the block at the cyl. wall? it
    sure is pissing me off though.
    sacramento
    Quote Originally Posted by turbo wog View Post
    i think the oil was from the drain tube on the other side leaking & seeping thru the heat shield & pipe due to no gaskets yet (test pipe) it felt tight !
    sacramento
    back to icieng up the manifold or frosting up . its a good thing? i thought i have heard people say if the tune is right it ices up > any comments /info guys?
    I will start with the first high five on a manifold that is icing! Mine does it all the time and it is a N/A deal and I frost up the manifold all the time! The one thing I would do is get rid of the "drilled" items and match to a factory replacement! Reason being that drilled stuff doesn't flow the same as a machined item and can create turbulence with the flow! I don't think it will change the tune as much as help a equal flow. Some of the Nitros guys might agree that a cold flow into the combustion chamber makes H/P. I will probably get BBQ'd for that statement but the colder the charge the better with gas! Mark
