[Question] Help with loader scoop selection
Results 1 to 3 of 3
    Jul 2012
    Delphos Ohio
    Default Help with loader scoop selection
    I have a 19'' Eliminator sprint it had a stock loader scoop in the berkely 12JG pump with the stock 454 making some where around 329 hp guessing . I am installing a 496 roller cam motor n/a will be on dyno this week enticipate it making little over 600 hp. I did drill out pump for bigger bolts just unsure of loader i do not want to put to much loader in it and slow me down. Next season a inducer ,ride plate, and snoot will be installed just funds right now low for this season. I do need a loader however due to the fact it is rusted and pitted bad and staring to get holes in it . Any suggestions on loaders would be great was looking at the ss super loader scoop good up to 500 hp expect to make 600 will that work or stock fine or different loader i know you can load it to much and kill mph Thanks Adam
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    you need to call a reputable jet shop and buy a new loader I'd suggest either B1 Racing or MPD
    '79' Eliminator sprint bailey's Avatar
    Concord, CA
    I run that ss loader on my sprint its a good starting point.
