455 olds logs
455 olds logs
    Junior Member jesse72455's Avatar
    Apr 2012
    Default 455 olds logs
    I was woundering on my water logs if i could re route the way the water exits the excuast and just run a hose through the hull for the exiting water to make the jet louder
    Sep 2011
    Soon, you will realize, the quieter...
    the better.
    But, no, if you want louder, go OT.
    Things are plumbed for a reason.
    Feb 2012
    OC, CA
    Don't find out the hard way. Do you have a big rubber hose connecting the logs to the exaust tips? If no water, you will burn them up.
    Default Bingo....
    Quote Originally Posted by Ol Blue View Post
    This is very true, don't ask me how I know..... Although you can't totally eliminate the water flow, you could redirect some of it overboard.... It is a fine line, but possible. As far as LOUDER??? Not sure where you run your boat but the noise pass most through transom exhausts get could be a thorn in your side if some Lake Ranger wanted to get shitty about noise...It's hard to muffle these systems with anything except water flow....
    Ray
    LOUD BOATS SAVE LIVES
