diverter mods for racing
Results 1 to 14 of 22
    Default diverter mods for racing
    can somebody post some pics of the mods done to the place diverter nozzle when used for racing?
    I know you add a plate and drill some holes
    #55
    Senior Member Pattymelt18's Avatar
    You can drill out the 1/4" bolts and put 5/16 for the arm on adjustment. Seen those break off before
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by Pattymelt18 View Post
    me too. especially if you're using a stop on that arm...
    What about adding a plate to the reverse chute and drilling holes on the side of the bucket?
    any pics of this?
    #55
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    I did that to mine. Ours is mainly a lake boat so I need reverse, but it was a biatch to hold steady on the rope, and there was no nuetral. I had seen where someone simply welded their reverse chute closed on a race boat, so I made a plate that fits perfectly in the reverse chute that is flush with the bottum of the diverter, has an ear welded to either side that sticks up in there, drilled thru each so all I have to do is bolt it in for the track. I took a pc of 1, 1/4 tube and welded it to the reverse bucket, took a rotary file and opened up the face of the rev. Bucket so water will spray out to the side. So far it has worked perfectly at the track, and I still have reverse at the lake. This is the best pic I have right now, you can barely see the 1/4" holes drilled in the reverse chute. Hope that's what you were askin about!
    2011 Rouse Performance 19'
    WFL Crew
    Quote Originally Posted by Alter Ego View Post
    yes thats what I'm talking about, Ive seen some close up pics of them on this site but cant find them now, I was thinking the bucket just had some holes drilled into the side though
    #55
    Jun 2010
    South Arkansas
    I have seen what you are talking about. There will be four to five holes drilled into the side of the reverse bucket so that the water can spray out to the side. Not sure if they drill the nozzle as well, or if there is a gap big enuff where the water can escape the nozzle, and spray out the sides. That's why I did what I did....I knew it would work. And if its done by someone who can weld real well, or someone who has the patience to smooth the weld back off, it doesn't look bad.
    WFL Crew
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    Here's how mine is, works like a champ. removable if i ever need to.
Name:	2012-05-09 22.21.20.jpg
    Heres a mod we have made using a butt bucket and closing off the oem reverse chute/nozzle ride plate ....
    Apr 2012
    Default confused here
    the first pictures look like it would eliminate the reverse, and toms pictures seem like it would make it more efficent. what exactly are we trying to do here (we-you, not we-with me, since i dont understand)
    Quote Originally Posted by $uperJoe View Post
    When racing...you need the ability to sit in one place....while idling.
    Apr 2012
    OOoohhhhHHH. that being said i see there is no need for reverse. its a pain in the control with the fine touch trying to keep the boat stationary on a lake. i could only imagine if there were multiple high performance things done to ones boat.
    so then maybe toms design points the water at the back of the boat for its own deflection. that would make more sense
    Senior Member speedealer's Avatar
    Albuquerque,N.M.
    if you can make the sit still the way it is you really don,t need to change anything. know several boats that just use the the stock setup and do just fine. matter afact raced 21ft sleek and had no problem at the rope. hope your planning to join us at the butte this weekend. would love to see that beautiful boat of yours
    With my PD set-up... drilled sides, and reverse chute blocked, I can make the boat change direction, ever so slightly to keep it pointed where I want. Best feature is no foreward movement, no hunting for neutral.
