what's my best next mod?
Results 1 to 14 of 29
    Oct 2011
    Default what's my best next mod?
    Ok new motor finally runs great( thanks for everyones help with that), no oil leaks, water leaks and gps'd at 70 mph. What would be the next mod for more speed? The pump is a 12jc with an A impeller. Completly stock. Motor made just over 500 hp at 5800 rpm. With the A impeller it's turning around 4800 rpm.
ID:	168600   Click image for larger version.
    " Live Laterally " Dominator's Avatar
    Phoenix
    Sky is the limit! I would start experimenting with your hardware you will be amazed what little adjustments can do to your boat. Baby steps though you don't want to get wet.
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    sacramento
    Quote Originally Posted by rpm0414 View Post
    sound like your rpm is too low to get all the hp . what was your hp at 4800?.
    Oct 2011
    Around 450-460hp
    Southwest corner AR
    It sounds like it is time to think about the impeller size! I have a bud that his motor makes 551 HP @ 5800 and he is turning a B impellor 5600 RPM! FWIW!
    WT
    WFL Crew!!!
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    I would start by getting a Place Diverter. Then you will be able to adjust the attitude of the boat. Never knew what I was missing, until I got one.
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    yup your next step should be the addition of a diverter.
    PLACE DIVERTER & CONTROLS - The Original Jet Boat Drive System:
    bullhead city
    I am in the same situation but already have diverter, next step for me is ss impeller as alum. should not be turned thee 5500-5700 rpm I need
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    Lightbulb
    Probably want to get a loader if you don't already have one also. I picked up a couple mph with the diverter and I've been told I'll get another couple out of a loader once I get one. Loader is cheaper than diverter.
    Southwest corner AR
    This is the chart that I use on checking an impeller to HP! Freeing up the motor and making it pull it's power will help! A diverter will help alot but will not get the most out of the motor! JMO!
    Jet Boat Performance, Impeller Power Calculator
    WT
    WFL Crew!!!
    B1 Racing cs19's Avatar
    Blueprint jet drive, slightly smaller impeller, place diverter and some sort of a loader if you dont have already, thats a start.
    B1Racing.net
    bullhead city
    was told not to run alum impeller over 5000 rpm or 500 hp
    Oct 2011
    What loader would be best?
    Oct 2011
    And if I did change impeller to a B, I guess I could turn the motor higher rpm but does that mean more speed? Or just higher rpm on motor and less thrust?
