Gale Banks Questions
Results 1 to 8 of 8
    Nov 2011
    Default Gale Banks Questions
    Still piecing together an old Gale Banks twin turbo system. I have scoured the threads on here and found a ton of good info....thanks all.
    Can anyone tell me what heads were used in these BBC packages as well as the camshaft specs?
    I am still in need of a carb box too.
    Thanks!
    SDBA #819 vdrivegrimes's Avatar
    Oct 2011
    I set of good oval ports prob would work and get a custom grind from bullet. Is a carb box a must have? Why not use a carb hat? Ive only seen one banks in person.
    Placentia, CA
    Banks was buying crate motors from GM and they had 990 heads on them. Engle TCS 7 flat tappet was the cam of choice of Race Arrow and PFM, not sure about Banks. Should use inconel or super alloy exhaust valves.
    steveo143 AKA DiMarco 21 II
    Nov 2011
    Default Thanks, perfect.
    Quote Originally Posted by steveo143 View Post
    Thanks, perfect.
    Senior Member tomply32's Avatar
    palm beach florida
    Default gale banks twin turbo
ID:	168808engle was also used in banks motors.I have a set up ready to put into my jet boat.I took the engine apart to make sure everything was built for the turbos.aftermarket dished pistons,square port heads that have been ported , an original gm hi perf intake that unfortunatly had all the casting numbers ground off and polished except for the underside date code .engle roller rockers
    Placentia, CA
    I actually have a slightly used, about 10 hrs, Engle TCS 7 sitting on the shelf. Probably better than a new one since the core is about 15 yrs. old when they were still making good cores. You couldn't give me a flat tappet cam for free that I would put in anything I was building.
    Nov 2011
    Default What hosepower version is this?
    Quote Originally Posted by tomply32 View Post
    I have the same intercooler and i know this is the larger kit. I have seen some with 2 Holleys and some with 1 Holley. I wonder what the difference is? I would rather run a single dominator rather than 2 carbs, no idea of what size though.
    Nov 2011
    Default Some parts needed
    I still need a carb box. Anyone? I would aslso like to round up some original Gale Banks valve covers. Need gaskets for the turbos also, any know where I can purchase those along with one of the tubes that goes between the turbo to the intercooler?
