[Question] New to Jet boats. can you use a std flex plate? bbc
Results 1 to 12 of 12
    Member lethal injection's Avatar
    Jul 2012
    Jerseyville Il
    Default New to Jet boats. can you use a std flex plate? bbc
    do you have to use a flywheel or can you use the std flex plate that came with my rotating assembly? is it too flimsy?
    Jan 2012
    Independence KS
    I think it depends on the rear mount your running? I am using a flexplate with a glencoe style rear mount.
    Jan 2012
    Independence KS
    Glennwood or niscon my bad
    Jul 2012
    Jerseyville Il
    Quote Originally Posted by KansasJet View Post
    Will be using a 3 point system ..top mount starter Thanks.!
    Jan 2012
    Independence KS
    If you have a new roto assembly you will want to run what came with it. Im in process of putting in an Eagle full roto in my BBC and its exteranly balanced. If your in the same boat ( pun intended) youll want to run the flex plate. Mine is rated up to 700 hp, so its strong enough. Not sure what you have but....? A flex plate will fit a bellhousing mount with ease.
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    It kinda depends on what the boat had in it before. If it had a flywheel in it u will need a spacer to take up the length difference so the pto reaches the pump
    Senior Member lilrick's Avatar
    Lakewood
    It really depends on RPM. Most jet boats live their lives under 5500 rpm and can get away with a std flexplate. More RPM, such as in a flatty would require a thicker flexplate Like CSR sells or a flywheel. I had an alum flywheel on my K boat, CSR thick flexplate on my pro stock boat, and a std flexplate on every suck boat I've had.
    And don't forget that your 454 Is probably externally balanced and will require the appropriate counterweighted flexplate.
    Jul 2012
    Jerseyville Il
    Quote Originally Posted by wpmxwb View Post
    The engine is a 468 BBC with Brodix heads 10.5:1 Comp Roller Marine cam Eagle Rotating assembly yes the flywheel is rated same as yours, just didnt know about the flex factor at the starter without a converter bolted to it or anything. Thanks for all the help! i was hoping i could run it this way!!! LESS WEIGHT! YEAH!!
    Default HP rating...
    HP ratings mean nothing in a jetboat. The drive line attaches directly to the crankshaft. The only reason you even need a flywheel/flexplate is for the starter.... Most recreational jets will never get anywhere close to "red lining" the RPMs..... I've seen 2 flywheels spit the ring gear off in a flatbottom that revved like flipping a light switch, but never hurt a flexplate in a jet....
    Ray
    LOUD BOATS SAVE LIVES
    Redding, CA
    Quote Originally Posted by lethal injection View Post
    Sounds like you stole the motor from our Miller!
    I run a flexplate just fine.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Jul 2012
    Jerseyville Il
    Thanks for all the help! last boat i built was the same hull but a stern drive new to the whole jet thing. if i can get it to 65mph id be happy!
    Senior Member applekrate's Avatar
    Maricopa & St Johns, Arizona
    Quote Originally Posted by lilrick View Post
    I'll agree on the 5,500 rpm UNDER LOAD but, they tend to buzz pretty high when they come out of the water! I know mine does anyway.
    www.pontiacheaven.org
    '72 Hondo Flat
    '74 Rogers jet
    Phil 2:11
