American Turbine ATJ ?
Results 1 to 12 of 12
    May 2012
    Default American Turbine ATJ ?
    I have a American Turbine ATJ-309 (model before the the AT-309) and it rattles at low idle. after some research I see that there is a zerk fitting inside the nozzle area. mine does not have this. Am I missing parts?
    1990 ultra 21' open bow. 509, American turbine Jet
    " Live Laterally " Dominator's Avatar
    Phoenix
    Tom at jet boat performance will know this question but I am curious to know if you have a stainless impeller or not?
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    May 2012
    Quote Originally Posted by Dominator View Post
    Thanks,. It is a new boat to me and have not torn apart. My guess would be no or the seller would have said so
    The question is does the noise dissipate or go away entirely when a slight load is put on the impeller (rpm increase) ? is the a rattling,clunking/growning noise your hearing while running on the trailer ? Likley if not a stainless impeller or bronze (heavy impellers cause this) its likley a phenomenum called "machine noise" which can result from a combination of wear between the pumpshaft male splines and the double Universal female yoke(splines) Noise is fairly common and not likley really a problem , call if you need more info Tom
    BTW re missing Zerk? are you refering to the lack of one looking in thru the steering nozzle at what would be the south end of the tail shaft ?
    Apr 2012
    Tom could this be cured by having the splined end of the shaft dipped in the blue teflon like coating that drive line guys are using now?
    Quote Originally Posted by $uperJoe View Post
    Joe your ahead of me on this "trick" ,IF the noise is more than one can live with it can be "lessened" with a new shaft or drivline depending on which is really worn , some say to dope the splines with silicone , personaaly I would live with the noise depending on severity
    May 2012
    yes that is the zerk I am refering too. It does make the noise on the trailer at idle and it does go away at a slight load or higher rpm. Hard to explain the noise, kinda like rocks in a can and you can feel it in the floorboards plus it is not consistant-not there some times
    Quote Originally Posted by limited View Post
    Doubtfull given your description that theres anything wrong beyond shaft and spline wear , I'd rock it Tom
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Had about 20 hours on a new driveline and shaft and it made that same rattle noise at idle.....no big deal I thu some grease at it and it helped for a while
    Aug 2012
    Default I have the same model.
    In inspecting the 22' boat I bought, I found out that the same model is in my boat. I'd love to share any information you have been able to locate. My turbine is also marked with a 9.25 DW behind the ATJ. I also do not have the zirk, sitting now at 101 hours, and hear the same thing you are hearing.
    Keep in touch. Performance wise, mine seems to be doing everything expected of it.
    Jan 2012
    St. Louis, MO
    Quote Originally Posted by cinouye View Post
    You wouldn't have a 22' Dana, would you?
    Jan 2012
    St. Louis, MO
    As Tom and others said, sounds like spline/yoke slop. Have the same thing on my AT-309 w/9.25" impeller. Turning the idle up a bit, so that the pump always has some load on it, helps get rid of it.
    Your "missing" zerk fitting probably just means you have the water-lubed bearing, like mine. You're looking at the end of the shaft when you look in the pump. No lube required....
    Matt
