QData 2 Config - 1v-5v Sensors
Results 1 to 3 of 3
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default QData 2 Config - 1v-5v Sensors
    July 19, 2012
    Hello People,
    I have two pressure sensors from my old system I want to use we my new Q Data 2.
    The rage is 0 Psi = 1v and 250 Psi = 5v
    How can I make these two gauge work?
    Willis
    Gardena, CA
    Quote Originally Posted by willis View Post
    July 19, 2012
    The rage is 0 Psi = 1v and 100 Psi = 5v
    The rang of the Edelbrock unit for 100 psi sensor is .5v= 0 Psi and 4.5v = 100 Psi
    Edelebrock 100 psi sensor Bit=3700 and Value 100.0 for .5v=0Psi and 4.5v = 100 Psi to record correctly
    What are the new bit and value #'s to calibrate for 1v = 0 and 5v = 100 ?
    Willis
    Gardena, CA
    Default QData 2 Calibrated - Working
    July 23, 2012
    Mark,
    Edelbrock Racing
    QD2/Nitrous/Electronics Dept.
    310-781-9303, ext.3021
    Thanks the data file are working fine
    Willis
