Trailer Modifications
Results 1 to 7 of 7
    Junior Member MikesB12's Avatar
    Apr 2012
    Oklahoma
    Default Trailer Modifications
    Not sure that I need to post this in the Jet section, but here goes. I've got a Competitive brand trailer under my Carrera 205 open bow that has the float bar or California bar on the trailer. From the get go, I've noticed the front of the boat bounces quite a bit while trailering. My plan is to remove the float bar and scoot the boat up about 1" (to match the V-Guide that's under the front of the boat).
    I'm looking for pictures, insight and anything else before I tackle this. I've envisioned one of those rubber V-guides under the bow eye and a nice winch to hold it all together....
    1989 Carrera 205 Elite Open Bow, Hardin 454, Berk 12JG. "Snake Farm".
    Sep 2011
    Los Angeles
    I gotta do the same thing with mine. If you have rollers it'll probably be easier but if not head to the lake and move it forward with the boat off. Does the back of the hull hang off the trailer?
    Apr 2012
    Oklahoma
    Quote Originally Posted by larryfknrocks View Post
    It doesn't hang off right now, it's about even with the end of the bunks. I'd just like to have a little board hanging out the back.
    Feb 2012
    OC, CA
    I take it the bar is welded and not adjustable. If so, I would move the bar forward and re-weld and continue to float boat on.
    Apr 2012
    Oklahoma
    Quote Originally Posted by Ol Blue View Post
    No, it's not welded at the moment. I could scoot it up for the time being, but I'd like a more permanent fix for the problem.
    If you do the rubber v- block, I would suggest putting the bow eye behind it for 2 reasons.
    1. If you get in an accident while trailering, the bow eye will hit the v-block and stop the boat from loading itself into the bed of your truck.
    2. You won't have to lift your boat up and over the v-block while launching.
    Personally I like the winch over the floater bar because you can get the bunks wet, then pull forward a bit. Winch the boat up onto the bunks so it's on straight the first time.
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    here's mine on the daycruiser
Name:	competitive trailer winch.jpg
    "Never mind the mule, Just load the wagon"
    '76 Eliminator 21'
