[Question] suction housing cracked...
Results 1 to 12 of 12
    May 2012
    Question suction housing cracked...
ID:	170410Click image for larger version.
    Can anyone tell me what would cause a crack like this in the suction housing?
    Second picture crack is colored yellow and is it repairable?!
    Thanks!
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Three point engine mount?
    May 2012
    its a four point
    Feb 2012
    OC, CA
    Its toast, replace it.
    The Right Coast/SE-PA
    Ugh, one of my biggest fears owning a Jet .
    Senior Member Futs's Avatar
    Orange CA, Big River
    I have cracked 2 right there. mine was from over charging the pump with real aggresive hardware hanging down.
    replace it. Next one i crack im going to a dominator suction housing.
    Default broken suction housing
    running over rollers at full throttle
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    I bet cavitation. That's what happened to mine. You will have more problems then that crack if you fix it.
Name:	broken jet pump 001.jpg
ID:	170453   Click image for larger version.
Name:	broken jet pump 009.jpg
ID:	170454   Click image for larger version.
Name:	broken jet pump 007.jpg
    Junior Member PE826's Avatar
    I'm pretty sure cavitation caused this to happen to mine. Took a blown alcohol 540 from ~7k rpms to 0 before I new what happened. No bueno for sure.
    PE 826
    May 2012
    water was smooth. and wasn't cavitating at all. bought pump used and crack wasn't there had out twice then this happened.
    They only take so many pressure cycles, then the above can happen. They were not perfect castings back when, and there are some out there with pretty bad core shift, thin walls. The new Dominator suctions are superior to the OEM Berkeleys.
    You guys are making me crawl into the fetal position...that's a fast way to the bottom of the river/lake
