Need to see Eliminator bubbledeck bottoms...
Results 1 to 7 of 7
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    Default Need to see Eliminator bubbledeck bottoms...
    I've been told by [email protected] that these hulls come with both a rounded/radius keel, and the "delta pad" bottom. I need to know what they both look like so that when I go and look at a boat, I don't end up buying the slower one. Thanks in advance, John.
    Johnny pretty sure the pic you showed in your other thread is a "Delta pad" Tom
    heres one (Delta) we did some work on for your comparison I'll try to find a "radius" pic too
    Surrey, BC, Canada
    here it is, doesn't have the same notch though.
    Ladera Ranch
    Delta pad can always be modified/eliminated if you find that you otherwise like a boat. May want to define your speed goal, in some instances you wouldn't know the difference.
    Surrey, BC, Canada
    I have a contour intake...can that be used on the delta pad bottom? my speed goal would be around 90.
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Quote Originally Posted by JohnnyNitrous View Post
    I have wondered this myself. My Bahner is a Delta bottom and I would like to go put a radius in it. Will I need to change the intake?
    Senior Member n8dawg's Avatar
    Santa Paula
    I have a '76 Eliminator Bubble deck. I'll have to snap some pics of it tomorrow for ya.
