bassett header gasket???
Results 1 to 7 of 7
    seattle
    Default bassett header gasket???
    recently purchased an old Eliminator with a 454 and bassett's ... it looks like it is running normal car exhaust manifold gaskets...they are definitely leaking...
    What brand of gaskets are preferred for use with these???
    S CP
    sixx st. seargant at arms snewton's Avatar
    p-town
    Quote Originally Posted by 1975sleekcraft View Post
    Percy's work real well.you can get them from jegs for $20
    Senior Member hotkona's Avatar
    Puyallup WA
    Remflex. Kinda spendy, but they work. And can be reused a couple of times.
    In thrust, we trust
    Oct 2010
    661 So. Cal.
    X2 for remflex. I was outraged at the price, but after installing running them I see why they are as much as they are. Good to go
    Sent from that vibrating thing In your pocket using Tapatalk
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    I had the same problem and now I put the sce copper gaskets on with silicone.
    Felpro 1411 or 1412 round port header gaskets. The 1411 is 1.94" dia. and the 1412 is 2.13" dia.
