'73 Kona Resto Build II
Page 1 of 27 1 2 3 4 11 ... LastLast
Results 1 to 14 of 376
    Las Vegas, Nv
    Default '73 Kona Resto Build II
    Well since Hot boat is taking it's sweet ole time about restoring pic's I will atempt to move the thread over here.
    Ok here goes.I have been wanting to write a thread following the progress of the restoration of My Kona,for a while now,but havent had the time to spend on it.
    However I will try to make the time When ever I can.
    Please keep in mind that some of the pics that I will be showing are of work that I have done on the boat more than a year ago.That being said and My limited budget,hopefully the tread will catch up to the present day progress.
    These first pics are when I went to Huntington beach to pick up the boat.
    I bought the boat less engine,but it did come with the basset water injected headers,and all the stain less braided hoses.
    The pump is a jacuzzi 12wj freshly rebuilt about 4 years ago but never ran after rebuild,with a place diverter.
    A litle story about the previous owner.Aparently he had
    a prety good motor in the boat ,and was running it at lake Mead,as He use to live in Vegas,when He got pitched from the boat.I guess He got scared of it and never ran it again.
    I guess before he decided that he was'nt going to drive the boat again,He had the pump done and new interior and carpet put in.
    The boat has been regellcoated,but the deck has a bunch of tiny cracks all over and other spots that are crazing. I later found that the cracks in the deck were in the glass too,but the other cracks were only in the gell.
ID:	9731   Click image for larger version.
    Las Vegas, Nv
    Ok here are a few more Pic's.
    These are from when I got the boat back to Vegas(back full circle).
    The boat had been sitting under a dark blue heavy cloth boat cover for four years,so it needed a good cleaning.
    From these pics and from a distance,You could not see the boat acne it had.
    Ok here is where it started getting intresting!
    I bought a 454BBC which was reportedly in good running order,rebuilt with about 5000mi,with 10:1.compresion ,with the intentions of just sticking it in the boat and go have fun.It was end of season and being the curious one,or skeptik,Idid not just want to take the word of another,I poped the pan off to have a look inside.lo and behold what did I discover ?A spunn bearing,I WAS PISSED! Any way I proceeded to tear down the engine .I pulled the heads first and made another discovery.It aint no 10:1 motor and further more one cylinder was really rusty .UHHO!Have I got a cracked block or head?
    I tore the motor completly down and off to the machine shop it went to cleaned and maged.
    well The block and the heads tested good,NO CRACK'S,but the one rusty cylinder could not be cleaned up,so it was time to bore.
    I talked with My engine builder and we decided to go with some more cubes,A STROKER MOTOR! Bored .030 and bought a Scatt 4.25 stroke rotating asymbly.
    Any way while I was gathering parts and with My limmited budget,and being hard headed and not wanting to settle for a lesser motor (i did not just want a stock motor) ,I started picking at the boat! For one the cracks in the deck were driving Me crazy! so I started contemplating fixing the deck, started there and one thing lead to another.You Know one of those ,while I am here I might as well fix this too,situations.
    Anywho here I am a year and a half later and I am still working on it! Oh well hopefully the end result will be worth it,When all is said and doneIt will practicly be a neww hull,as I have filled every hole except the transom cutout,and replaced every pice of wood,except the wood glassed into the deck.I think it will probobly even be built better than Kona built it the first time!
    I am calling It a reso build instead of a restoration ,becouse while the hull is a classic It will be updated and modernized to almost a custom boperformance boat....Hal
ID:	9733   Click image for larger version.
ID:	9734   Click image for larger version.
ID:	9735   Click image for larger version.
    Las Vegas, Nv
    Here are a few pics of what the deck looked like up close .
ID:	9737   Click image for larger version.
    Las Vegas, Nv
    Ok here are a few pic's of the interior ,before we get into the ugly stuff!
    Well next we will be getting to the ugly stuff of getting rid of the boat accne replacing the wood and the fun fiberglass work...Hal
ID:	9743   Click image for larger version.
ID:	9744   Click image for larger version.
ID:	9745   Click image for larger version.
ID:	9746   Click image for larger version.
    Las Vegas, Nv
    Default Starting the Uglies
    Ok well while I was waiting on My engine to be built,I was sitting here staring at the deck on the boat.Every time I would look it over I would tell Myself,Man i should fix this! After a while I started picking at the deck.I had seen Roostwears Stevens thread ,and He was scraping the paint with a razor blade,and I thought would this work for Me.
    I started scraping and it was working
    Aha! The original gell,Silver metal flake!
    Ok! Well this scraping is taking way toooolooong! Time to break out the big gunns!
ID:	9748   Click image for larger version.
    Las Vegas, Nv
    Default Taking the boat off the trailer
    Todays update .
    The razor scraping is taking too long. I will have to grind the rest of the gel off with a power tool,But first being that I guess I will go ahead and re paint,I need to get the boat off the trailer and onto a dolly that I built.
    I went ahead and removed the rub rail from around the boat. When I got it removed I was surprised that there was no hull deck seam It apears that the huhh is some what capped,but is cracked in spots.I don't know if this is a factory deal or an after thought?
    To get the boat off the trailer I decided to try Squircha's method ,with the two engine hoists.I have allready removed the pump ,so I will have to use the transom eyes to lift,hope it holds.The hull does'nt seem to be all that heavy,so I dont see a problem.
    Got her all hooked up and started to lift
    Off the trailer we go!
    Free hanging,Hope nothing goes wrong now!
    Bottom shot.Got some work to do here.
    ready to go on dolly.You can see the dolly in the background.
    Well the two engine hoist method worked like a charm. Very cool idea Squircha! It was easy as pie!
ID:	9750   Click image for larger version.
ID:	9751   Click image for larger version.
ID:	9752   Click image for larger version.
ID:	9753   Click image for larger version.
    Las Vegas, Nv
    Default Update
    Ok! Well let's see if we can catch this thread up some.
    I got the boat off the trailer and onto the dolly for better working access.
    I needed to grind all the gell coat off the deck,down to the bare glass to make sure that all the cracks go away .When I got down to bare glass I found that there was a ton of tiny cracks in the glass itsself.The cracks were very tiny and bunched together all over th deck,almost like at some point there was a bunch of weight placed on the deck. Maybe someone too heavy walked on the deck? Any way there were too many and they were too small to V-grind and fill back with glass.
    I called Todd(Toddnjuzz) at TRG fiberglass,to see what route He thought I should take. He gave Me a couple options,one of which was to lay up a layer of mat followed by a layer of cloth,over th entire deck then blocksand it down. Todd said that is what they did to Cyclones deck on his Rogers and it worked great,So that is what I did. Deck grinding
    __________________
    Las Vegas, Nv
    Default More deck grinding
    Here You can see the original gell coat ,which was silver flake with blue flake graphics.
    Down to the glass
ID:	9760   Click image for larger version.
    Las Vegas, Nv
    Default Fixing the nose
    Before I glass the deck I need to Fix a spot on the nose.
    If You look at the nose in this pic You can see the bad spot.
    I filled in the bad spot with glass,then laid up layers of glass over it.
    Las Vegas, Nv
    Default Fixing the nose continued
ID:	9763   Click image for larger version.
ID:	9764   Click image for larger version.
ID:	9765   Click image for larger version.
ID:	9766   Click image for larger version.
    Lexington, KY
    Talking
    Pointy!
    HJ
    Las Vegas, Nv
    Default Laying up the deck
    Ok ,I got the deck laid up with a layer of mat and a layer of cloth.
    First I laid out the mat and cut it to fit the deck,then cut the cloth to fit ,so every thing would be ready to go
    I used vinylester laminating resin for the layup,and added some sufacing agent to the final coat to harden non tacky.I had to work at night and under catylize the resin,due to the heat here in Vegas.
    Here is the deck cured and ready for block sanding.
    I got one ripple in the final layer,that I had to grind a little before blocking.
ID:	9776   Click image for larger version.
ID:	9777   Click image for larger version.
ID:	9778   Click image for larger version.
    Las Vegas, Nv
    After sanding down the glass layup,I skimmed the whole deck with a mixture of finnishing resin and microballons to fill in the low spots(not shown),then blocked that down.Then as a final fairing I used a pollyester putty to finnish fairing.
ID:	9780   Click image for larger version.
    Las Vegas, Nv
    Thumbs up While Im here.
    Well I was'nt really planning on replacing the stringers,but there I go again looking at things too long!
    After looking them over realy good I found that they were still very solid,but I can see that the glass has delamminated from the wood,and they were very ugly.
    I cut out the stringers today.I just took a side grinder and cut about a 1/4" above the hull,on both sides of each stringer.Then with the stringers removed,I took a sawsaw and cut down alongthe hull and the remaining glass to make it smooth.
ID:	9782   Click image for larger version.
