help!! please
Results 1 to 14 of 31
help!! please
    Feb 2010
    Default help!! please
    hey guys havent ran my boat in two years . its a tahiti jet with a 454. i took it out of the garage ran some new oil checked the plugs fresh fuel in the tanks. turned the key barely and she fired right up. i connected my garden hose to my main line. started it again turned on the water and water was coming out of the block on either side in two fairly heavy streams??? two ports on either side and there seemed to be some sand in there im.probably a total idieot but i need some help thanks guys.
    Put your head down there and see where it is leaking. Does it get cold enough in your garage to freeze? Maybe rusted out freeze plug.
    Quote Originally Posted by DSDANO View Post
    Perhaps someone opened the block water jacket drain cocks before it was "laid up" last ?
    Maybe removed the drain plugs on each side when you stored it away and forgot?
    Come on, this isn't rocket science. Get your head in there and see where the water is coming from!
    Feb 2010
    i know its not rocket science and i have stuck my head in there its two open ports. i never took any plugs out for sure. can they just rot away?? i just dont know much about motors. sorry for being a dummy guys
    Feb 2010
    i just read into it i guess i should have done that first. they must be the frost plugs and have rotted out
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    Or the water froze and the freeze plugs were pushed out by the ice....... by design, this helps to prevent the block from cracking due to freezing.....but not always
    Long Beach
    Quote Originally Posted by SNiC View Post
    The holes in the block have nothing to do freezing weather and plugs being pushed out by ice. They're there for casting purposes when the block is sand cast. It's just a core plug. A block in a freeze will crack wide open with the plugs still in it.
    Yep. Just because it may have popped a freeze plug, its no guarantee that it didn't do more damage.
    If it gets cold enough to freeze where that boat was stored, consider yourself lucky of the block isn't crack. You simply dodged a bullet.
    Feb 2010
    idont think it would be due to freezing i cant find the plugs and i live on vancouver island the coldest outside it gets here in the winter is like -5 for a day maybe two. and plus its kept in a heated garage. but i guess you guys know best.
    Feb 2010
    whats weird is the red sand in the motor ive never taken it anywhere with that much sand or red sand to boot. i bought it second hand from cali maybe it was in there when i got it.
    Senior Member rebel30's Avatar
    Oct 2011
    Twin falls
    Water freezes at 0 degrees Celsius and 32 degrees fahrenheit even if it's only 2 days if there's water in the block from not being winterized and it gets cold it will freeze . The red sand has probly been in there for a while and you need to flush the block if it's not already toast.
    Surprise, AZ
    The red sand you see is most likely RUST!
    Senior Member TrollerDave's Avatar
    Chino,CA
    Don't be sorry for that.
    Are you able to take a picture and post it?
    That would help a lot.
