Fixing an impeller
Results 1 to 14 of 20
Fixing an impeller
    custom member raped southwind's Avatar
    so-cal
    Default Fixing an impeller
    I have hit a brick wall today. Finally got the impeller off and this is what i have found. Not sure if its worth fixing but i cant afford the new ss Impeller this yr. I have an alum impeller but i think that will do more harm then good. Any advice or sugestions. Trying to get back on the water this yr!
    Surprise, AZ
    If you are worried about running an alum impeller, I would defiantly toss that one in the trash. What kind of power are you running?
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Stainless is repairable.but that almost looks like really bad casting flaws.
    Okmulgee Okla.
    I don't think I would put that back in if it were mine I would opt for an aluminum to finish out the season,and be looking into another stainless and wear ring for next season.
    well the block is GM any ways
    IS UNDER FIRE
    so-cal
    motor is a 496 that soposedly made roughly 700 on dyno. Id say more along the lines of 600 but wont have an accurate guess untill i get the specs off the cam. None of the holes are burnt through. its mainly on the surface that mates to the wear ring and then the outer edge. What causes this. It was in a little 18ft with a 396????
    Surprise, AZ
    A guess, casting flaws. How old is that impeller?
    Surprise, AZ
    Quote Originally Posted by raped southwind:1686382
    What rpm's did you turn it? Wait, I'm confused. 496 or 396?
    so-cal
    Quote Originally Posted by 67weiman View Post
    New motor is 496. The pump came out of an avenger with 396. dont know rpm of the old motor!!! age is unknown!
    Senior Member SBS933's Avatar
    Jun 2012
    Default Whoa
    That definitly not electrolisis, looks like crap stainless. I have seen cavitation damage like that before. A few years back we had a lot of problems due to taking lead out of impellers and not getting the new formula right. They have got it right these days though.
    so-cal
    Totally shitty. Only pitting on the impeller is where it's shown. Leading and trailing edges are immaculate .
    so-cal
    Thinking about tig welding the holes, chucking it in the lathe and then having it rebalanced? Anyone see a problem with doing this and who can re balance it. Or am I gonna be stuck with the old school bubble balance concept?
    Jun 2012
    Default What ?
    Quote Originally Posted by raped southwind View Post
    If your lucky that impeller will turn into a sharp meat grinder,otherwise it could grenade. I would keep iy on your workbench and see how many people ask questions. Take another route.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Take it to MPD and see what Jack has to say about it. I know what i would do with it, but jack might be able to save it, if not he will tell you straight up!
    Jul 2009
    Send it to Jack. If it's worth fixing, he will do it right. If it's not worth fixing, he will tell you.
