MSD advance settings-
Results 1 to 10 of 10
    Senior Member Factory502's Avatar
    Default MSD advance settings-
    I just picked up an MSD ready to run distributer, and it has several different advance springs and stops, does anyone have any suggestions as to what a good set up is- I believe it has the stiffest springs, so the slowest advance set up, it is going in a mild bbc with a comp cam 280AH-10 cam- I can get the numbers if needed- Thanks
    TEN THIRTY ONE RCB19's Avatar
    Lock the advance out. There is absolutely no reason to have an advance curve in a jet boat. Then set your timing to it's total at 3000 rpm minimum.
    RCB
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    Quote Originally Posted by RCB19 View Post
    I dont understand this can anyone tell me y this sould be locked I know when I run my boat with more advance i pickup speed but it will hardly start but when I set the timeing to were it will start right I lose speed the advence seems to be just the ticket whats up
    Quote Originally Posted by TahitiRat View Post
    A jetboat motor is rarely ran under 3k. Motors in this app like timing instantly in order to build torque/hp cleanly. If you have a sluggish or late advance curve it can cause the motor not make instant power when you crack the throttle. If you must run a curve due to hard starting set a curve so the total advance is in by 1500 to 1800 rpm. If your starter, cables, battery etc. are all in good condition you should not have a problem turning a motor over with a moderate total advance such as 34-36 degrees and moderate compression. If the motor is getting up there in compression a better starter/MSD start retard electronics might be needed with a locked out distributor.
    RCB
    sixx st. seargant at arms snewton's Avatar
    p-town
    exactly, and if u get a box with a start retard it will retard the timing 20 deg. until the engine reaches 800 rpm to allow for easier cranking!
    Fort Worth Texas
    cool I may have a week link in my start system I have some bad wire fixen to do alot of work on the boat thanks sorry adout the jack
    Cantard 71hallett's Avatar
    snow bank
    If its locked why 3000rpm? I would also lock it. Light springs increase carb fires.
    p-town
    cool I may have a week link in my start system I have some bad wire fixen to do alot of work on the hole boat thanks sorry adout the jack
    how far is the the msd box from the battery and tyhe starter. is the battery in good shape?
    Fort Worth Texas
    Not running a msd right now just geting the parts to gether to do the ign. swap when I get rid of the olds and install the BBC but before that boat will be completly rewired along with alot of glass work thanks
    also the battery is a new interstate
    A slight load on the motor is a good idea when setting the total with a t-light. 3k and above is just a good point to check this. But one does not have to if they choose. There is always a slight amount of slop no matter what in the cam drive system.
    RCB
