Oil blowing out of breather
Results 1 to 14 of 16
    Senior Member Quit Yer Bitchin's Avatar
    Jul 2010
    Default Oil blowing out of breather
    460 Ford running 5qts 10W30 and a quart of Lucas oil stabilizer. First I was using a built in pcv breather with a hose running to the back of the carb. Cruzing at 60 with the engine reving at 3,000 the crank case pressure would build up and blow it out of the gromet. The dip stick would pop out too. No the pcv was not stuck. Changed to regular non pcv breather and oil would leak out of it. Switched gromet to a baffeled gromet and problem persists.
    Surprise, AZ
    New rings might help.
    Quote Originally Posted by Quit Yer Bitchin View Post
    Approach it by running a wet dry compression test and a cylinder leak down test , sounds like blow by These test will devulge information to help diagnose Tom
    Okmulgee Okla.
    6 qt capacity I would be looking into a larger oil pan as well.
    well the block is GM any ways
    IS UNDER FIRE
    Member Rude Louie's Avatar
    Mar 2010
    Rocklin, CA
    Look into a pan vac system
    Inland Empire-Big River
    Quote Originally Posted by 67weiman View Post
    Yep & Yep. That much oil and pressure at that rpm would have me leaning in this direction first.
    We wash our parts in gasoline,
    We drink Alcohol,
    And we go racing with Nitro-Methane!
    Sep 2011
    Los Angeles
    im going thru the same damn headache
    Jul 2012
    Way NW
    Quote Originally Posted by Wild Hair View Post
    Ditto!!!
    Shell Knob, MO
    Default oil blowing
    Why are about 90% of all of the engine blowing oil threads about 460 Fords?
    Duane HTP
    Surprise, AZ
    Quote Originally Posted by DuaneHTP:1688345
    Duane HTP
    That might stir the pot a little. Lmao
    Shell Knob, MO
    Didn't mean it that way. Just sayng---------------
    Duane HTP
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Same problem lol, with a Ford 460
    Sep 2011
    Because fords suck, let's be real here!
    Feb 2012
    OC, CA
    Quote Originally Posted by 525SC777 View Post
    Please expain your comment. What knowledge do you have on the subject. We would like to know.
