What impeller do I have?
Results 1 to 14 of 29
    Member BergerDirn171's Avatar
    Nov 2011
    Edgewood,NM
    Default What impeller do I have?
    Has anyone heard of an Aggressor A, B, D aluminum impeller? I broke my impeller two weeks ago and I finally got it apart. I thought for sure that I had an A cut impeller. It has A stamped on the left side and B and D stamped on the right side. My guess is that it is an older aggressor. This is my first jet boat so I am learning a lot. Ill post some pictures if that helps. Thanks for your guys help in advance.
ID:	171968   Click image for larger version.
ID:	171969   Click image for larger version.
ID:	171970   Click image for larger version.
ID:	171971   Click image for larger version.
    My guess is, it started life off as a A then cut to a B then cut to a D.
    More then likely your running a D impeller.
    No matter what u can always take material off your impeller and make it smaller, ie (A to B) but you can never put it back on, ie (B to A)
    The real experts will chime in shortly.
    also do u know how much HP u have and what RPM does it turn?
    Nov 2011
    Edgewood,NM
    I never thought of it being cut in to a D. I have a stock 454 my guess would be 300 hp. Correct me if im wrong. I see around 4800 to 5000 rpms at full throttle. It comes out of the hole really good.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    it is not a "d." that appears to be an aggressor A that is missing a big chunk. The bd probably stands for berkley design or something. if it had been cut ud see a reveal between the blade and the back edge. as you can see yours goes all the way to the edge. if it was a AA it would actually go past that edge sorta hanging off.
    Quote Originally Posted by BergerDirn171 View Post
    Well 300hp is not going to turn a A impeller to 5k unless you pump is as warn as a $2 hooker.
    I spun a stainless A to 5200 with 525hp with a pretty well set up pump.
    my stock 460 spun my aluminum a to 4600 and it maybe made 300 hp on a good day
    well it is missing half a blade after all
    Quote Originally Posted by HBInHeat View Post
    So did it spin 5k before or after throwing a blade?
    Why would the impeller have a D stamped on it if it was a A?
    Nov 2011
    Edgewood,NM
    Ok I see what your talking about. I was thrown off by the extra letters. Thank you for your help I appreciate it.
    Nov 2011
    Edgewood,NM
    Yeah it definitly would turn 5000 rpm. I was confused as well. I thought maybe it was just an older style of impeller.
    here is a c imp for comparison now imagine a d if that existed
    Why anyone would stamp letters into a impeller that have nothing to do with the size of the impeller is wild, especially specific letters that correlate with specific sizes.....
    Oh well.
    Is that a bahner?
    a pump that has poor tolerances will spin at a higher rpm and give you a false rpm reading. id recommend buying an impeller and ware ring from a shop like b1 or mpd or whoever is near you and have the set the correct tolerances. i wouldn't imagine youd want anything smaller than an A if this is a family ski boat that your going to be tubing the kids or towing a skier with.
