scoop mounting
Results 1 to 14 of 16
scoop mounting
    Senior Member slotracer's Avatar
    Default scoop mounting
    lets try this over here seeing must of the boys down south run them
    got a scoop with the base plate and need to know how to mount it up. any pictures or tips on how to mount it?
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    DJD
    DJD is offline
    6TH STREET MAFIA PRES. DJD's Avatar
    Closer to the river than you!
    You can get a nice tray from a company called gaza. I know a few people that use them for a single carb deal.
    thats goza
    phone number or website?
    slot
    87 eliminator
    Stockton, ca.
    Glendale Arizona
    Summit or Jegs Pat.
    Goza scoop tray for single carb
    Goza scoop tray for dual carbs
    You might need this adapter too for 4150 carbs
    Looking at a couple hundred bucks to mount a scoop. Or you can make your own. It's really pretty easy.
    I made mine from some 1/8" aluminum. Nice n sturdy and pretty straight forward. I can send you some pics if you want to see it.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Summit or Jegs Pat.
    Looking at a couple hudred bucks to mount a scoop. Or you can make your own. It's really pretty easy.
    Or..I just glassed a base to the bottom of the scoop and used some SS1/4-20 button heads to mound the scoop to the 4500 series carb flange (Velocity ring?) so the entire scoop is fiberglass except for the aluminum mount to the carb and the bar stock that mounts over the carb, i know that i will probably hear that i am disrupting the flow over the carb, but,....its just a river boat!
    The whole deal was finished in a few short hrs and all of the products can be found @ home depot.
    Todd
    DJD
    DJD is offline
    Quote Originally Posted by thecraz View Post
    thats goza
    OOPS my bad im kinda new to this scoop stuff but i do know how to spell ENDERLE and GORR. i was just trying to help cause nobody posted to answer his question after a day and a half.
    Glendale Arizona
    I knew what you meant Danny.
    This sucker did sit for a bit didn't it?
    looks like the adapter will work. dan could you please send me some pictures of yours?
    thanks
    slot
    87 eliminator
    Stockton, ca.
    DJD
    DJD is offline
    Ya it sat for too long it was a shame to see it just sitting and going to waste.
    come on now guys you socal boys just don't like us nor-cal boys and keep your secrets to yourselfs
    slot
    87 eliminator
    Stockton, ca.
    Colfax, Ca
    Tre built some with I think with alumium but steel would work. e used a piece of tubing that would slip over the bolt in the center of the carbs and then weld flat stock to it like rocket fins. He used 4 on each carb. That way they are not disturbing the air flow and if anything straitening out the flow. They worked out fairly well even withstood the nitrous blast.
    Colfax, Ca
    Hey Cy,
    Pretty sure I understand what Tre did, any chance of a pic???
