Is there a sweet spot for the shoe , as related to the drop keel ?
Results 1 to 6 of 6
    Atlanta TX
    Default Is there a sweet spot for the shoe , as related to the drop keel ?
    In the pic , the shoe is about 5/16 above the keel.
Name:	shoe related to keel.jpg
ID:	172274   Click image for larger version.
    Senior Member lupo1904's Avatar
    Feb 2011
    i was a 1/16 below now im an 1/8 below but still playing with it,you need to drill and tap the intake to get a pressure reading to see if the bottom of the impeller is loading.loader feeds the top and shoe feeds the bottom. let the fun begin
    Quote Originally Posted by cpjet View Post
    What boat what power etc etc more info the better
    Just a qwik question JPB? Do you see a shim in his future???
    Atlanta TX
    19' Daytona , 583ci , 1500+ hp.......Run short track only , 660-1000' max.
    There is some shim in the shoe, comes out to either 825 or 845 cant remember rite now.
    B1 Racing cs19's Avatar
    No!
    This is not a v bottom, don't relate the shoe to keel on something like this. Too many variables like keel depth and keel type. You need to test to establish your ideal biting edge.
    You will always be above keel on something like this (fast tunnel boat) when things are right.
    B1Racing.net
