Pop off clamps
Results 1 to 7 of 7
Pop off clamps
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    Default Pop off clamps
    Does anybody know where I can get on stainless steel clamp for a Miersch pop off? I can make on out of steel on my mill, but would rather have stainless if possible.
    Thanks for any help, Ryan
    Quote Originally Posted by slowboy View Post
    They can be made out of aluminum if you make them correctly. With the flange on the suction housing being so small the strength of a part is in its height. Just make sure you use as long of a bolt as possible so you get maximum thread engagement.
    If you don't want to make them call Chris at B1 Racing (949)294-1394
    Slowboy, I've seen one piece 2/3 collars on popoff's too, A stepped collar, with 1/3 of it cut out on the back side. They clamp 2/3 of the way around, installed at the opening, and rotated into place, and bolted. Custom piece I'm sure, but you can machine them pretty easy.
    Feb 2009
    Default clamps etc.
    There is also a new aluminum clamp with a bigger footprint available. You can get it from Chris at B1 Racing.
    -L
    Pro Gas Jet RedPearl's Avatar
    Ausitn, TX
    Default John mills makes the horseshoe clamp
    John and Ralph designed the horse shoe clamp after customers were losing valves in the lake. this clamp solved that problem. tested at over 160 mph's
    John Mills 951-545-2266
ID:	172525Click image for larger version.
Name:	Rick Rusbult.jpg
    Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic!
    Duluth, MN
    Quote Originally Posted by RedPearl View Post
    I am going to go ahead and give John a call. Thanks for all the help!
    Duluth, MN
    Hopefully this valve will simmer my CP tunnel down a little bit on shutdown.
