Carb help
Results 1 to 6 of 6
Carb help
    Apr 2012
    Tucson
    Default Carb help
    I picked up this boat recently and I'm finally getting around to tinkering. It has 2 Holley vacuum secondary carb. I have never had vacuum secondaries and noticed the vacuum canisters are just connected to each other and that's it. Doesn't seem right to me maybe someone here can chime in on this and explain the thought process. Thanks. I tried uploading a pic but wont work from my phone.
    CAPTAIN KRYLON
    Jul 2009
    LEWISVILLE TX
    The diaphram gets it's vacuum / lack of vacuum signal from the body of the carb.
    There should be a rod through the bottom half of the housing that connects the diaphram to the secondaries.
    On multible carb applications some link the two together to insure an equal signal.
    Apr 2012
    Tucson
    Thanks for the reply. I guess I just don't know where the vacuum comes from if the canisters are just connected together with no other vacuum lines, anywhere .
    CAPTAIN KRYLON
    Jul 2009
    LEWISVILLE TX
    There is a port on the carb body that meets a port on the inside of the vac canister with a small roung cork gasket. By having the canister on the carb body the connection is made.
    Quote Originally Posted by cubegenie View Post
    vacume source is thru a small passage in the side of the carb body sealed between the servo and the carb with a small oring (cork/paper) The tube is an attemp to "equalize" the servos to get them to open simutaneously Tom
    Apr 2012
    Tucson
    Makes sense now. Thanks for the help.
