Do baffles affect power?
Results 1 to 14 of 16
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Default Do baffles affect power?
    I was reading in the "water in baffles" thread and heard a few talk about power loss and rpm change with the addition of baffles.
    Is this something all engines will be affected by or just ones built up fairly heavily?
    My TX19 has a pretty stock 454. Just a mild cam and a hirise dual plane with a 850 holly and a locked out dist. Thats all I know about it so far.
    I have Bassett twisty headers with bassett baffles. The baffles that look like a glasspack inside, not the twisted noodle style.
    I have heard that the twisties run a little quieter than other header designs? My friend has twisties with No baffles and its not very loud at all. Is there some truth in the "quieter" theory?
    Can I expect to gain any RPMs or power? Or am I just gonna have to pull them and see?
    Chop,
    Years ago I had a 13.75-1 Olds with a pretty hefty cam, tunnel ram with 2 660's, and Bassetts. It would turn 5900 open and 5700 with Bassett mufflers. I was running an A-B impellar. After I lowered the compression and went with a milder cam I don't believe I ever removed the mufflers, So I am not sure on a milder build if it would be that much of a difference.
    Also the original high comp motor was as loud with mufflers as most seemigly stock motors were without. With mufflers I was asked to leave my local lake.
    I hope this helps
    Bob
    Mar 2010
    Clarksville, TN
    I'll loose about 400 RPMS when I run mine
    New here Beer:30's Avatar
    Bakersfield, CA
    Nothing is free. There is always a trade-off. Noise and HP are linear. If you quiet it down, you will lose some HP.
    Also depends on the set up and the "tune" have had engines that didn't seem to mind a bit of silencer at all
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    my 500hp 460 will loose 400-500 rpm with baffles
    Quote Originally Posted by justsquirtin View Post
    Years ago I tested every baffle on the market. You absolutely loose power with baffles. The Bassett one you have are the worst in terms of robbing power. Like the others said, it's routine to lose 400-500 rpm.
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    I run the dynatech cones with no noticeable rpm loss. But I also don't notice a noise drop.
    I have ran the spiral bassetts and noticed a big difference in both noise and power
    Pretty much what beer:30 said
    If it makes it quiter, it will cost you power. Its that simple. Specially when you don't have the room to build and design a proper muffler. When we had to run mufflers at the Long Beach Marine Stadium, everybody ran big huge Flowmaster box mufflers. Quite and a minimal power loss. But they were HUGE with a 4" in and out along with big 4" turn ups.
    Anything that you stuff up a collector is going to rob power. Period. Like Cyclone said, some worse than others.
    The more more the motor makes, the bigger the loss. Its simply air in, air out. More power=more air. You try to shove 1500HP of air out a bassett glass pack type, and you kill more power than the average 454 even makes.
    Less loss as you go down the scale, but you have to be way down there to say it had no effect. Way down there.
    The best header deal I have ever ran, with the least power loss on a 850 HP deal was these. Hands down, bar none. No they aren't pretty, the just work. Cheaper than a Borla, almost as quite, and you could run water thru them it you had to.
    Bakersfield, CA
    I never thought you were a QUITER? I don't know how a muffler can be QUITE, though. Unless it flows QUITE well?
    Picking on my dyslexia again asshole?
    Bakersfield, CA
    Just seeing if your sensitive side was still out on your sleeve. Guess it is.
    Oct 2011
    Puget Sound Wa
    Well its time to try it "loud" style.
    The Right Coast/SE-PA
    I haven't run w/o my Bassett "performance" baffles out in a looooong time > wonder if I could do it for a day > and NOT get a ticket
