Pulling jet boat motor
Results 1 to 12 of 12
    Senior Member blefever's Avatar
    Bishop, CA
    Default Pulling jet boat motor
    I need to pull the motor out of my new to me 1975 Weirdt Stinger to replace a oil pan gasket. 460 Ford with Berkley Jet. It looks pretty straight forward to me but I have never pulled the motor on a jet boat.
    My question is how the motor connects to the jet. I see what looks like a main bearing cap with two bolts connecting the bell housing to the jet. Do I just pull the cap and un bolt the front mount and pull her out? Is the u joint a spline connection into the pump? Any help would be much appreciated.
    "Improve your sex life......buy a boat"
    Senior Member lupo1904's Avatar
    Feb 2011
    The u joint is a splin connection, disconect the drive shaft from the pto and pull the motor
    Feb 2011
    You might be lookin at a drive shaft cover or the rope seal tensioner bolts, take a pic and let us see what you got going on
    Bishop, CA
    Will take pics tomorrow, thanks.
    Oct 2010
    661 So. Cal.
    Sounds like you have A three point mount in your boat.the main cap looking thing it the clamp that hols the bell housing to the pump. Unbolt the two bolts, un bolt the front of the motor and pull her out. Yes the driveline is splined, and will slide right out.
    Bishop, CA
    Quote Originally Posted by SuperJet View Post
    I do think your right about what I have. That's what it looks like, but that sounds way to easy, I'm thinkin there's got to be a trick here. Thanks for the help.
    LaGrange GA
    Quote Originally Posted by blefever View Post
    Nope, easy as hell getting it out.
    now putting it back in is another story. sometimes those damn splines just don't want to slide back on!
    Senior Member SBS933's Avatar
    Jun 2012
    Do yourself a favor ,and find a good driveline shop and refresh the universal while it is out.
    Default Mark it.....
    Quote Originally Posted by Slow Boats Suck View Post
    If you do pull the u joint assembly apart, MARK IT FIRST... Use a center punch to leave reference marks as to how it was assembled/clocked..... You can change the u joints yourself if necessary, but it sounds as though it is just an oil leak that needs attention.... I've seen u joints last for decades, and I've seen newly installed u joints fail within one season..... Resort back to the old saying, "if it aint broke, don't try to fix it".....
    Ray
    LOUD BOATS SAVE LIVES
    Feb 2012
    OC, CA
    Quote Originally Posted by earlbrown View Post
    x2
    x2
    Bishop, CA
    Thanks Guys. Working on this boat is a piece of cake compared to my Baja. Dosen't require near as many MF's
    LaGrange GA
    Less MF's is always a good thing
    and bitches. Sometimes bitches can be the worst
