stumped
Results 1 to 14 of 37
stumped
    Jul 2012
    Default stumped
    first of all i am a body man not an engine mechanic i know just enough to be dangerous so ill explain my problem. i ordered a new set of valve covers for my 468 and i put them on last night i cranked it up just long enough to make sure everything was ok and the rockers were not hitting the cover everything was ok, this morning i was gonna take it to the lake so i was gonna start it for a sec and it would barely start and now it will not idle and it is also backfiring through the carb it has a holley double pumper on it. i replaced the plugs, wires, rotor, cap and coil today and its still doing the same thing. im thinking maybe its the valve or possibly a worn cam. any info would be greatly appreciated
    Any noise? Like ticking? Pull the valve covers and start it. You may have a crossed plug wire if you took them off. Just recheck everything you touched.
    Jul 2012
    i checked all the wires twice they are in the right place it starts pretty easily it just sounds like it not running on all 8 cylinders until you rev it then it sounds almost right but then it usually backfires through the carb and dies
    New here Beer:30's Avatar
    Bakersfield, CA
    Been sitting awhile? Old fuel? Dirty fuel maybe plugged the carb and now it's lean?
    If nothing is broken in the valvetrain, back-pop through the carb is a LLLLOOOONNNNNGGGGG flame from a LEAN mixture. Check your fuel supply.
    Apr 2009
    San Diego, CA
    Maybe distributor 180 degrees out?
    Bakersfield, CA
    Quote Originally Posted by WMorton View Post
    Wouldn't run at all.
    self proclaimed idiot Adam_R's Avatar
    Dec 2011
    Corona Ca.
    so you just changed your valve covers? was the distributor moved or removed? On a BBC you can have 5 and 7 crossed and it will run like what your saying. When I run into problems like this at the shop I stop and start over from the start. Roll the motor over and check your valve train as well. Good luck.
    Jul 2012
    i never pulled the distributor so its not 180 out all i did was replace the valve covers the motor has ran fine up til now and the gas is not old either i checked all the plug wires and im positive they are correct
    Quote Originally Posted by bighoss View Post
    Put the old valve covers back on and see if the problem goes away. also did you remove a vac line from the back of the carb and forget to plug? Mark
    Bakersfield, CA
    If you KNOW the ignition is right all the way through.....it has to be carburetion.
    Do you have another carb you can put on - maybe borrow one? Doesn't have to be same size or anything.....just one that will run on the boat to verify.
    Jul 2012
    nope no vacuum lines removed like i said after i put the valve covers on last noght i cranked it and it ran then this morning when i cranked it it sounded funny like it was missing thats why i changed all the plugs wires cap rotor and coil it has ran perfect until this morning thats why im concerned about it
    whats a goodtime cost? Nixonnow's Avatar
    Feb 2011
    Fort Mohave, Arizona
    We're they pre made wires? If they weren't and you made the cut to fit ones. Maybe some of the connections are loose?
    FAT GUY IN A TPR STEALTH NO REGRET$'s Avatar
    MENIFEE . CA
    CHECK FOR WATER IN THE FUEL how long has the boat been sitting ????
    check the firing order if chevy 18436572
    "Life's tough......It's even tougher if you're stupid."
    -John Wayne
    ..JUST HAVING FUN..
    . . . .SIPPY CUP RACING. . . .
    MySpace URL:
    http://www.myspace.com/dp734taj
    What rockers, What Cam and What Valve covers ? and it ran fine before or how long since its been run prior ?
