Jet Trouble
Results 1 to 6 of 6
Jet Trouble
    Default Jet Trouble
    I am running a Berkeley JE pump on a 79 wisconsin ski boat. It has a AA aluminum impeller. When I am at a stand still and push down the throttle I get up to about 20mph and the the RPMS top out and I only hold that speed. If I back off of the throttle some the pump will seem to catch up so to speak and then I can nail on the throttle and its fine. I checked the packing glad and the seems to be fine. I am under the inpression that I am getting a vacuum leak in the pump. Is this correct and if so were would I start looking to find it.
    Thanks Brian
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    Sounds like a severe case of cavitation. Did u check to make sure there's nothing in the intake grate? How's the impeller look from the intake grate side or hand hole?
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    If nothing is stuck in the pump or obstructing water flow, then it might just be time for a rebuilt pump.
    Was it fine before, or is it a new to you boat?
    Quote Originally Posted by Problem Child View Post
    Thanks Brian
    The feeling of "tire spin" you describe does suggest something going on with the jet for sure if no debris , Your E pump should produce crisp thrust on intial take off and plane with relative ease , you may be on track looking for "leaks" The 12JE is typically sealed to the hull with Epoxy (possibly PL5200) , that bond should be complete and solid , the cleanout cover is a potential source of atmospheric leak as well as the packings (you indicate you checked) , check all around the base of the jet casting to hull connection as anywhere the jet can draw air versus water it will If all this is good , It may be time to pull the bowl and take a look its simple and straight forward Tom
    Default Wood chip or twig....
    I once had a similar experience that turned out to be a wood chip, about the size of my little finger from the last knuckle to the end.... Motor would rev, but the pump would slip....If I eased up to it, I could get maybe 20.......I beached the boat and opened the clean out, and the chip floated out...Problem gone.....
    Ray
    LOUD BOATS SAVE LIVES
    Sorry for the delay in my responce, I have been tied up with work. This problem has been happening since I started running the boat. I did rebuild the pump about 3 years ago. Everything internally was replaced. I did look at the intake and there seems to be some of the sealing epoxy being used to smooth the transition from boat hull to the intake. There is a small area that as come lose from the hull itself and looks to be creating almost a pocket the would catch in coming water. If a wood chip could cause such issues i would assume this could cause a lot of problems. I will cut this excess away and take it out for a run.Thanks for everyone's help.
