hull and intake tips and info
Results 1 to 1 of 1
    Dec 2009
    monterey bay area
    Default hull and intake tips and info
    I have a 73 sanger superjet that i would like to get some info from the pros about. Is there REALLY any reason not to use the sanger intake adapter other than just because its a one-off piece? I plan to set the pump back, while i am doing this is there any benefit to doing a dropped keel/ spoon to the bottom? I would like to get everything i can out of the bottom of this boat the first time around if possible and would like to hear some real pros and cons of doing these mods as they are not qouck and easy to do or remove, Thanks Travis
ID:	173060   Click image for larger version.
ID:	173061   Click image for larger version.
ID:	173062   Click image for larger version.
ID:	173063   Click image for larger version.
