any good jet boat shops in sac?
Results 1 to 13 of 13
    Broke Member monstertahiti78's Avatar
    Feb 2012
    Folsom, CA
    Default any good jet boat shops in sac?
    I finally got everything put back together and I cant seem to get the motor tuned just right. It fires up but wont stay running without my foot in it. Seems to need some more valve, carb and timing adjustment. Im finally out of options(aka want this thing on the water already) with this being my first time doing all of this. Anyone know of any shops in Sacramento that could do a tune up for me? Im not looking to spend an arm and a leg but I know its not going to be free.
    Nate
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Nate,
    Pulling it a couple of hours to Jim at Performance Jet in Sebastopol would be well worth it. Are you sure you don't have a vacuum leak somewhere?
    Feb 2012
    Folsom, CA
    Nate,
    Thats a good idea. I may have to look into taking it down there. It could be a vacuum leak but I think that I just cant get the combination of valve adjustment and timing right. Ive never done this before so that could also be the problem. haha. I found a shop that said they could do it for around $150 but I wanted to see what else was out there.
    Junior Member Mateo's Avatar
    Shingle Springs, CA
    Quote Originally Posted by monstertahiti78 View Post
    Nate
    Try Bill Morgan "Southwind boats in rancho" 916-600-6938
    Ive had some good luck with him lately and he has been very fair
    Feb 2012
    Folsom, CA
    Quote Originally Posted by Mateo View Post
    Thats where I was at this morning actually. He seems to be the only hotboat place in town. All of the other boat places back away from those projects. Someone mentioned pirate boatworks on florin perkins but I cant get ahold of anyone there.
    Colfax, Ca
    If you want to bring it to Colfax, I work for beer!!!!
    Is this real or the "Twilight Zone"?
    Feb 2012
    Folsom, CA
    I wish you would have mentioned it earlier. I pretty good at helping while drinking beer I just dropped it off at a shop in rocklin the other day. colfax isnt that much further....
    Colfax, Ca
    Maybe next time. This is definitely thirsty weather!!!!
    May 2010
    Discovery Bay, CA
    Nate
    Sounds like you don't have initial timing I had the same problem with mine Depending on your cam I had to put 16deg at idle (1100rpm) to get it to stay running with a total timing of 36 @ 3000rpm It was a simple spring change on my distributor
    Break Out AnotherThousand
    Feb 2012
    Folsom, CA
    agreed!! i feel like i could suck down a keg while wrenching......actually that might be a bad idea.
    Feb 2012
    Folsom, CA
    Quote Originally Posted by orange bahner View Post
    hopefully its something simple like that. im not sure what cam is in the motor so im thinking figuring that out is my first step
    Dec 2011
    Do you take foodstamps??
    Okmulgee Okla.
    Had an issue with mine doing the same thing. had the floats stuck and pumping gas out the overflow. Would only run when butterfly's were open giving it enough air to burn the excess fuel, just a thought.
    well the block is GM any ways
    IS UNDER FIRE
