glass work and setting intake back??
Results 1 to 3 of 3
    Colorado Springs
    Default glass work and setting intake back??
    I bought this 80 Haskel tunnel, the intake setup sucked, well actually the whole boat was completely jury rigged, I now have an empty hull. So far I have filled all the holes on the rails. Is there any info or article on this sight that covers filling in the hole and doing the glasswork for setting back and intake and filling the gell cracks inside of the keel. I plan on using an agressor or similar intake. Thanks
    Senior Member Flyin-Bryan's Avatar
    Aug 2010
    Ladera Ranch
    Try a search. Lots of info on this site. One way of doing it involves using some aluminum plate to bolt to the intake to lengthen it and cover the hole. Use the cut out from the setback and fill the underside of the plate as a filler. I tried this with success, but if I ever do another setback Id probably glass up the portion not covered by the intake.
