Impeller Question
Results 1 to 7 of 7
Impeller Question
    Jun 2012
    Default Impeller Question
    I have 525 bbf pushing about 450-475 hp in front of a fresh built berkley pump with an A impeller. My boat will not exceed 4800rpm and tops out at 65-67mph i spent about 4 grand over the winter on a ride plate new carb and tune droop snoot and place diviter and other misc. stuff and there was no difference in top end. Is the a impeller holding me back?
    Quote Originally Posted by Pup70 View Post
    Just curious if those HP numbers are predicted or from a dyno ? and are you positive that you do for certain have an A impeller ? Tom
    4800 395.68
    4900 420.92
    5000 447.23
    5100 474.6
    Jun 2012
    The motor was dyno at the shop were it was built and it is A impeller
    From the dyno pull then where does the engine make its power
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    Is this in your 21' daycruiser? If so, 65-67 is pretty damn respectable IMO. FWIW, I have an 18' with about the same horsepower, no ride plate, that turns an A impeller around 4900-5000 @ couple mph over 70.
    Jun 2012
    I dont have the dyno sheets anymore my house went up a few years ago luckly my boat was sitting at a freinds house at the time for interior work. As far as the top end what can i say im greedy i want to kick my brother ass he has an 08 chapperal 26' 496 FI
    Surprise, AZ
    Spray it.
